Aaaaaaaaarrrgggggghhh!
Brassmonkey
Post by Brassmonkey » Mon Aug 05, 2024 6:32 pm
Hi All,
So, I have a new addition to my stable; a nice Mamod SL3...
Looks like she's never been steamed, however when I steamed her, I noticed that water/steam was escaping out of the whistle.
No problem, I thought. I'll swap it out for the new high pressure valve and the original pressure valve for the new water top up valve (which I bought to go in the SL1K project - don't ask).
Still seems to be losing water from somewhere. I see the water literally drain from the boiler in around 30 seconds of running. Also, the pistons seem a bit drippy. Is that normal?!
How do I use the water top up valve? Seems really difficult to pump water into it. Am I being obtuse?!
Any help would be much appreciated as I'm tearing my hair out with it!!!
Also I'm using that fuel gel as I can't get solid fuel anymore. Should I dump the lot and fit my 3 wick meths burner?
Thanks,
Tim
Scrat
Re: Aaaaaaaaarrrgggggghhh!
Post by Scrat » Tue Aug 06, 2024 7:34 am
Hi Tim,
if the water drains from the boiler I do not expect anything in the steam line or cylinders.
If you can, put compressed air to it (low pressure) and hold the whole loco into a bucket of water.
You can see where the air bubbles come from.
For a detailed search I use dishwasher liquid. Simply apply compressed air and put a few drops on pipe connections, boiler seams and any other possible leaks.
You will get lots of bubbles where the leak is.
I suspect a leak on the boiler joints.
The cylinders are cold when you start running, so the steam will condense. That´s normal.
Hope this helps.
Brassmonkey
Post by Brassmonkey » Tue Aug 06, 2024 2:54 pm
Thank you!
I will give it a go tonight though I have a sneaking suspicion it may be around the reversing lever/block assembly...
It's a nut and bolt job by the looks of it anyway...
On a slight tangent, I fired my Hornby G100 Stephenson's Rocket (as I needed a break from the Mamod). I felt much better after!
Boustrophedon
Post by Boustrophedon » Wed Sep 18, 2024 12:51 am
I'm sorry but the only advice I can give is to sell the Mamod and buy a Roundhouse Millie second hand or a 'Janet' from https://www.evanssteamservices.co.uk/janet
