Have I got a problem?
Post by philipy » Fri Jul 12, 2024 9:54 am
I'm not sure if I have a problem or not, so any thoughts are welcome.
This is an Octoprint screenshot of the temps of hotend and bed on my Creality CR20pro when printing a temp tower.
Both lines show constant very small flickers which I don't remember seeing before but then again I haven't looked for it!
The actual temps are flicking between about +/- 0.5 deg of the set temp, which is probably what those little flicks are recording. So, have I got a problem developing and if so any idea what it might be?
I should add that actual prints seem to be OK.
Screenshot 2024-07-12 09.45.23.png (573.32 KiB) Viewed 57450 times
Re: Have I got a problem?
Post by ge_rik » Fri Jul 12, 2024 1:35 pm
I don't know, but I suspect the blips are actually to do with a conversion from analogue readings from the thermistor to the digital values handled by the software. I imagine that in reality there is a steady and uniform drop in temperature from start to finish.
Post by philipy » Fri Jul 12, 2024 2:22 pm
Rik, Sorry, I may have inadvertantly misled you. The steps in the graph are simply the 5 deg temperature drops at each stage of the temp tower print. What I was referring to is the slightly jagged 'straight line' if you look closely, as opposed to a flat straight line.
Paul_in_Ricky
Post by Paul_in_Ricky » Fri Jul 12, 2024 5:25 pm
I wouldn't worry about such small variations. There's bound to an amount measurement error in the hardware, plus as Rik says, there'll be software conversion and display errors too. At 200+ half a degree is only a 0.25% error.
Post by philipy » Fri Jul 12, 2024 6:57 pm
Thanks Paul.
I'm not really worried, I just happened to read something recently and only when I looked closely did I see the minor flicker, which had me wondering. :roll:
It prints fine, which is all that really matters.. until it DOES go up the spout! :lol:
Post by GTB » Sat Jul 13, 2024 4:35 am
philipy wrote: Fri Jul 12, 2024 9:54 am The actual temps are flicking between about +/- 0.5 deg of the set temp, which is probably what those little flicks are recording. So, have I got a problem developing and if so any idea what it might be?
The last figure in any measurement is uncertain. My opinion is the machine designer was kidding himself if he thought the hardware could read a temperature to the nearest 0.1degC. Most digital readouts of one sort or another flicker in the last digit when a reading is somewhere near the middle of that digits range. Which is why I prefer analog meters.
If your maths is still up to it, this teaching note on uncertainty of measurement covers the subject. :study:
https://www.deanza.edu/faculty/lunaedua ... ties2A.pdf
The target analogy at the end is commonly used to explain the difference between accuracy and precision, but a statistician colleague where I worked had a simpler way of putting it. "Precision is something we measure. Accuracy is what God knows....."
Have fun,
ps. I looked up the specs for a typical thermistor. Accuracy was quoted as 1%. That's just the sensor, there will be tolerances on the electronics as well. Correct practice is to add all measurement uncertainties. If I had to quote that bed temperature in a report, what you'd get would be a result of 60 +/- 2 degC (ie. it's somewhere between 58 and 62).
GAP
Post by GAP » Sat Jul 13, 2024 6:23 am
I have 2 printers running right now using Octoprint and I can see similar blips on the temperature lines, the bed temp more so than the nozzle temp.
I didn't even notice them till I looked real close after reading this thread.
Short answer is no I do not think you have a problem, if you do I have the same one.
Post by philipy » Sat Jul 13, 2024 7:44 am
Cheers for the replies guys.
As I said, I didn't really think I had a problem because my prints are fine, but something I read did make me wonder.
Paul_in_Ricky
Post by Paul_in_Ricky » Sat Jul 13, 2024 9:25 am
GTB wrote: Sat Jul 13, 2024 4:35 amps. I looked up the specs for a typical thermistor. Accuracy was quoted as 1%. That's just the sensor, there will be tolerances on the electronics as well. Correct practice is to add all measurement uncertainties. If I had to quote that bed temperature in a report, what you'd get would be a result of 60 +/- 2 degC (ie. it's somewhere between 58 and 62).
I think this is why so many people have problems with FDM printing. One might hope that our machines are reporting true figures, but manufacturing tolerances mean that can't happen. So we have to test and adjust as we see end results.
It would help if manufacturers gave correct spec for their products. I've just been trying out a new filament from Sunlu; The web page for it lists two different temperature ranges on the same page and if you download their technical data sheet for it, it's different again. Although that spec is only really applicable for one nozzle size anyway.
Exasperating stuff.
GAP
Post by GAP » Sat Apr 11, 2026 8:52 am
Sorry late on parade3 here but while upgrading my Ender3V3SE with an all metal hotend I has an issue with it low temp alarming.
When troubleshooting I came across a suggestion to do a PID tune.
Looking at what PID is I came across this.
PID tuning prevents is temperature oscillation — where the nozzle temperature hunts up and down around the target instead of holding steady. For example sitting at 200°C but swinging between 195°C and 205°C repeatedly. Poor PID can cause:
Slight inconsistency in extrusion
Occasional under or over extrusion as viscosity changes with temp
In bad cases, thermal runaway faults mid print.
Poor PID can cause:
Only worth doing the PID tune if you notice:
Temperature warnings during prints
Inconsistent extrusion that you can't explain otherwise
Thermal runaway errors
I didn't do it as my PID as shipped is OK.
I have noticed small variations in octoprint as well but no trouble with anything.
For me that is a comfort
