Hi All,
Newbie here, I have an old Roundhouse Russell and although she has steamed up to pressure and the valve has lifted the pressure gauge is not showing any pressure.
Thinking it was a fault with the pressure gauge I bought a new one from Roundhouse and fitted it. No leaks evident.
Re-steamed up to pressure and still no pressure showing in the gauge.
Everything else is ok, she runs beautifully on the track, just nothing showing on the pressure gauge.
Any help or suggestions would be much appreciated
Cheers
Paul
Pressure gauge
Re: Pressure gauge
So it would appear to be a blocked siphon tube. Remove the gauge, empty the boiler and try some vinegar in the tube to dissolve the lime deposits. Give the boiler a thorough rinse out afterwards.
Good Luck.
Good Luck.
- allsteamedup
- New User
Re: Pressure gauge
Hi Grant, Thanks for your help.
will do it at the weekend
Paul
Paul
- allsteamedup
- New User
Re: Pressure gauge
Hi Grant,
many thanks for your help.
vinegar worked a treat.
Russell is chuffing around the track and seems a little better on the throttle too.
Cheers
Paul
Cheers
Paul
