Using Repetier-Host
GAP
Using Repetier-Host
Post by GAP » Sun Dec 31, 2023 8:25 pm
After seeing a post by philipy where he mentioned Repetier-Host in https://gardenrails.org/forum/viewtopic ... 1&start=20 (Nov 13 2023) I became curious about what it was.
I had a quick read of the blurb on the Repetier website about Repetier-Host and it looks like it is all an singing all dancing piece of software.
The impression I get is that it could perhaps allow me to replace my Cura slicer (Cura Engine is built in)and Octoprint using Repetier-Server.
This may be worth further investigation.
Re: Using Repetier-Host
Post by philipy » Sun Dec 31, 2023 9:22 pm
Yep it does appear to do all sorts, but I've never really investigated, I only ever use it for it's repair ability. .Do a drawing -> export stl--> run it through Repetier, -->re export stl --> transfer to slicer. I do the same routine for both resin and fdm, but obviously use either Chitubox or Cura as appropriate.
Post by philipy » Sun Dec 31, 2023 9:55 pm
lisamerlot wrote: Sun Dec 31, 2023 9:28 pm With that program are you able to take photos of people and use it to produce miniature figures for a railway set? Has anyone ever done that on here? Would be interesting to know if it can be done.
Lisa
I'm not sure that Repetier can do what you are asking but there was a thread which included this subject, not too long ago. https://gardenrails.org/forum/viewtopic ... ri#p173710
