Resin Material Alliance
Post by philipy » Tue Dec 12, 2023 7:41 pm
I'm probably way behind the times, but just found this from 3 months ago and it sounds potentially very useful, although I haven't yet actually investigated it yet.
https://all3dp.com/4/chitubox-launches- ... liance-ad/
Re: Resin Material Alliance
Post by drewzero1 » Wed Dec 13, 2023 5:32 am
Sounds like it could potentially be a valuable resource. Pity about the acronym though... (I usually associate it with Return Merchandise Authorization-- when a device has failed and the manufacturer is offering to take it back and replace it.)
