Making "steam" from an atomizer for making mist
mymodeltrain
Post by mymodeltrain » Wed Nov 22, 2023 2:04 am
I gave up running live steam locomotives for a while, but I still missed the steam, thus, I decided to make "steam" for the LGB Stainz. It turned out that this small atomizer from a mini-humidifier (https://www.amazon.com/dp/B0CGN4QC3K?ps ... ct_details) seems to be the best one.
https://www.youtube.com/watch?v=q6K39tzZzEI
Re: Making "steam" from an atomizer for making mist
Post by philipy » Wed Nov 22, 2023 5:51 am
Thats quite impressive. Can you give us more detail on construction i.e water reservoir, wiring, etc?
mymodeltrain
Post by mymodeltrain » Wed Nov 22, 2023 7:17 pm
philipy wrote: Wed Nov 22, 2023 5:51 am Thats quite impressive. Can you give us more detail on construction i.e water reservoir, wiring, etc?
Here is the file, which details the design.
Atomizer connection.docx
(9.57 MiB) Downloaded 3480 times
mymodeltrain
Post by mymodeltrain » Wed Nov 22, 2023 8:05 pm
mymodeltrain wrote: Wed Nov 22, 2023 7:17 pm
Atomizer connection.pdf
(4.21 MiB) Downloaded 3581 times
Post by philipy » Wed Nov 22, 2023 8:14 pm
Great, thanks a lot. How long does one water fill last?
mymodeltrain
Post by mymodeltrain » Wed Nov 22, 2023 8:21 pm
philipy wrote: Wed Nov 22, 2023 8:14 pm Great, thanks a lot. How long does one water fill last?
I have not had a chance to test. But the wick is 5 cm long, and the chimney can carry quite a lot of water (I need to calibrate how much). I will play around this Thanksgiving weekend and will let you know; can't wait to see how real that would be in the garden.
Post by drewzero1 » Wed Nov 22, 2023 8:41 pm
I've seen them available as just the component, with a bit more range in input voltage: https://a.co/d/awqu5dY , also https://a.co/d/ir2ABTL
I'd been looking into one to add mist to a waterfall feature I'm building in one of my aquariums. Maybe I'll pick up a multi-pack and try adding one to a loco as well. (Incidentally Philip, I made the Thornas smokebox and chimney hollow with the hope of adding some kind of smoke generator in the future.)
Post by philipy » Wed Nov 22, 2023 8:45 pm
Thanks for those links drew. They also appear to be available from Amazon over here as well.
drewzero1 wrote: Wed Nov 22, 2023 8:41 pm (Incidentally Philip, I made the Thornas smokebox and chimney hollow with the hope of adding some kind of smoke generator in the future.)
Not hijacking this thread, but my smokebox & boiler are more or less full with lead and Rx!
mymodeltrain
Post by mymodeltrain » Thu Nov 23, 2023 1:18 am
I just tested this evening. The reservoir can hold 7 mL of water, and the steam is generated for as long as 20 minutes.
Post by Trevor Thompson » Thu Nov 23, 2023 9:31 am
I had wondered if there was a way of adding a plume of steam to a battery loco, when you have added a sound card its the one missing element.
A very interesting idea. I will store it away for future consideration.
mymodeltrain
Post by mymodeltrain » Thu Nov 23, 2023 3:12 pm
Trevor Thompson wrote: Thu Nov 23, 2023 9:31 am I had wondered if there was a way of adding a plume of steam to a battery loco, when you have added a sound card its the one missing element.
The Stainz locomotive was controlled by the wifi-based Locomote board and the sound is from the Mylocosound board, all are located in other freight car, including the 14v Lithium-ion battery and the speaker. The wiring for that can be found at the Locoremote website (https://www.locoremote.co.uk/lrdocs/Batteries.pdf). So the wiring scheme for the "steam" shows only the components on the Stainz, except the battery. I just need to link the Stainz to the freight car for running. For this setup, it needs to dial up to 75% Speed in the Locoremote wifi control to have "steam".
mymodeltrain
Post by mymodeltrain » Thu Nov 23, 2023 8:08 pm
mymodeltrain wrote: Wed Nov 22, 2023 2:04 am I gave up running live steam locomotives for a while, but I still missed the steam, thus, I decided to make "steam" for the LGB Stainz. It turned out that this small atomizer from a mini-humidifier (https://www.amazon.com/dp/B0CGN4QC3K?ps ... ct_details) seems to be the best one.
It looks good in the garden today:
https://www.youtube.com/watch?v=21LW9tUw2hA
Post by philipy » Thu Nov 23, 2023 9:12 pm
mymodeltrain wrote: Thu Nov 23, 2023 8:08 pm
Certainly does! Looks very good indeed. :salute:
gregh
Post by gregh » Thu Nov 23, 2023 9:50 pm
Congratulations for getting it to work. Looks great.
I will put it on my "projects" list
Do you get water droplets condensing on the loco and wagons?
Greg from downunder.
Post by Peter Butler » Thu Nov 23, 2023 10:41 pm
That's the best steam impression I have ever seen.
mymodeltrain
Post by mymodeltrain » Fri Nov 24, 2023 1:25 am
gregh wrote: Thu Nov 23, 2023 9:50 pm Congratulations for getting it to work. Looks great.
The atomizer generates tiny aerosols, which will dissipate quickly in the air; thus, there are no droplets on the loco or wagons.
mymodeltrain
Post by mymodeltrain » Fri Nov 24, 2023 1:27 am
Peter Butler wrote: Thu Nov 23, 2023 10:41 pm That's the best steam impression I have ever seen.
Thanks, Peter; I enjoyed my Thanksgiving holidays in the garden.
Post by -steves- » Fri Nov 24, 2023 8:09 am
In the Uk you can get these from Temu at a reasonable price.
https://www.temu.com/uk/small-flower-mi ... 48ytx4a5ze
Post by -steves- » Fri Nov 24, 2023 8:10 am
Or you can get a DIY kit from AliExpress, though I have no idea how good/bad it would be, just what I found browsing for similar items.
https://www.aliexpress.com/item/1005004 ... 03666568_8
Post by philipy » Fri Nov 24, 2023 8:21 am
-steves- wrote: Fri Nov 24, 2023 8:09 am In the Uk you can get these from Temu at a reasonable price.
Are Temu reliable? I've always avoided them because they seem to sell so much varied junk at ridiculously low prices that I assume they are scam/rip off merchants.
