Dual gauge point; well sort of.
Tony Bird
Post by Tony Bird » Wed Nov 08, 2023 8:20 am
Hi,
It is unlikely that many people will need to do something similar but might give ideas for other projects.
https://youtu.be/QIzGOCcEd1s?si=0USIPRKSd8sO93zP
Take care Tony.
Re: Dual gauge point; well sort of.
Post by ge_rik » Wed Nov 08, 2023 10:10 am
Clever piece of engineering. Hope you get the gauge issue sorted out
Post by drewzero1 » Wed Nov 08, 2023 2:48 pm
Looks great Tony! My own railway barely has room for one gauge, let alone two, but this definitely gives me some ideas. I really appreciate the step by step process since I'm hoping to build a set of points at some point.
I spotted your name in a book this week as well, which was pretty neat!
Tony Bird
Post by Tony Bird » Thu Nov 09, 2023 8:31 am
Hi Rik,
The gauge problem has been corrected, it was mostly caused by having to fit the point to the track bed at arms length and not being able to look directly down on it. A few minutes with a file and it was fixed.
Take care Tony.
Post by ge_rik » Thu Nov 09, 2023 8:39 am
Tony Bird wrote: Thu Nov 09, 2023 8:31 am Hi Rik,
Take care Tony.
That's good to hear. From the video, I thought the gauge for the 32mm track had widened and the wheels were dropping into the gap, but looking again I see they were rising which was, from what you say, a lot easier to cure.
Tony Bird
Post by Tony Bird » Thu Nov 09, 2023 8:51 am
Hi,
If you decide to make some points this might help. I do make more conventional points as well, but this style of point is simpler to make and very tolerant of the different types of wheels that might run over it.
https://youtu.be/WbWBE3MTUro?si=wh5zet5CNkwofB64
Take care Tony.
