3D printed vacuum hoses
3 minutes of fame
Post by 3 minutes of fame » Wed Aug 09, 2023 12:36 pm
Having failed to find any suitable files, I asked a good friend of mine to draw something up. This is the result.
If there's any interest, I will sell these for £12 for 6, UK postage included.
I can scale them as required to 7mm, 16mm, 1/32 etc. Just let me know the size you would like.
Vac Hose 16mm.jpg (46.83 KiB) Viewed 26867 times
Vac hose.jpg (21.38 KiB) Viewed 26867 times
Re: 3D printed vacuum hoses
Post by Phil.P » Thu Aug 10, 2023 1:49 pm
Can you produce a version with a 'saddle' on the large pipe at the bottom?
I want it to go under the end of the stock, and be fastened to underside of the cross-member.
It just gives a little more surface area for the adhesive..
Thank you,
3 minutes of fame
Post by 3 minutes of fame » Thu Aug 10, 2023 5:40 pm
I'm sure the answer is yes. Do you just need a flat bar section a few mm into the pipe section, located on the upper side of it?
Post by Phil.P » Thu Aug 10, 2023 8:03 pm
Yes please..
3 minutes of fame
Post by 3 minutes of fame » Fri Aug 11, 2023 2:02 pm
How does this look? I've added in a small landing plate to assist with gluing in place.
Vacuum Pipe.PNG (43.59 KiB) Viewed 26781 times
Post by Phil.P » Sun Aug 13, 2023 9:23 am
That looks to be perfect..
I just need to think of a compromise size, which will do for a couple of ideas I have.
3 minutes of fame
Post by 3 minutes of fame » Sun Aug 13, 2023 9:35 am
Not an issue with a mix of sizes. I've also created a couple of alternative designs for LGB and other manufacturers, as easy replacements or swap outs.
3 minutes of fame
Post by 3 minutes of fame » Sun Aug 13, 2023 10:22 am
Herewith the 4 options now available - plus of course, the ability to scale to any size.
I've added a version with underbody support, plus a couple to fit existing LGB stock.
