wheel centers
wsrbloke
wheel centers
Post by wsrbloke » Sat Feb 25, 2023 3:40 pm
Hi everyone, I am considering scratch building a class 66 in gauge 1. Most of the dimensions I've found online but I can't find the wheel center one anywhere. If anyone can supply me with it I would be most grateful.
Thank you in advance.
Ron
wsrbloke
Re: wheel centers
Post by wsrbloke » Sun Feb 26, 2023 11:25 am
Hi again, If any of you own a gauge 1 class 66 could you possibly measure the wheel centers on a. bogie and let me know what they are please. Your help would be much appreciated.
Ron
Re: wheel centers
Post by philipy » Sun Feb 26, 2023 12:44 pm
Ron, I don't want to be negative, I'd love to be wrong, and no harm in asking, but I doubt that any of our members would have such a beastie I'm afraid.
wsrbloke
Re: wheel centers
Post by wsrbloke » Sun Feb 26, 2023 1:12 pm
Hi, o.k, it was just a thought. I understand considering the cost of one. That's why I intend to scratch build one for myself eventually.
Ron
Re: wheel centers
Post by Phil.P » Sun Feb 26, 2023 2:31 pm
Errrrrrr................. :oops:
Give me a few minutes.. I will see if I can put my hand on one of mine..
:lol:
Re: wheel centers
Post by Phil.P » Sun Feb 26, 2023 2:53 pm
Right..
I don't know how to reduce a photo on the Smartie-Phone, and the camera makes it look like the ruler does not line up with the wheel centers.
Across the three axles, is 145mm
They do appear to be equally spaced, so 72.5mm between each.
Please be aware, I have not paid anything like the silly prices, being asked of late.
PS> If you want pictures, then message with an email address, and I will see what I can do.
wsrbloke
Re: wheel centers
Post by wsrbloke » Sun Feb 26, 2023 3:27 pm
Thanks very much for that Phil, From the scant info I found I think you are about right with the dimensions. I will try and mock a bogie up in Tinkercad and see what it looks like.
Ron
Re: wheel centers
Post by ge_rik » Mon Feb 27, 2023 7:14 am
Result! Thanks for coming to the rescue, Phil
Re: wheel centers
Post by Phil.P » Mon Feb 27, 2023 9:42 am
wsrbloke wrote: Sun Feb 26, 2023 3:27 pm Thanks very much for that Phil, From the scant info I found I think you are about right with the dimensions. I will try and mock a bogie up in Tinkercad and see what it looks like.
Ron
If you come up with a half-decent side-frame, I would be quite interested..
I assume your research has found information on the Aristocraft bogies for these? - Quite a feat of engineering, to get two motors, and three gearboxes, in each. Articulated, as well.
Re: wheel centers
Post by GTB » Mon Feb 27, 2023 11:22 am
Which of the gauge one scales were you planning on using for this beast?
The dimensions Phil.P quoted seemed a bit big for 10mm:ft scale, so I did some digging. The Class 66 are supposed to be fitted with EMD HTC bogies, in which case a bogie will have a total wheelbase of 13' 7", equally divided. In 10mm scale that works out at 134mm, with wheel centres of 67mm, so the Aristocraft models would appear to have been made to the larger 1:29 scale used in the US.
wsrbloke
Re: wheel centers
Post by wsrbloke » Mon Feb 27, 2023 12:41 pm
Graeme, I am indeed modelling in 10mm as always. From what I have found the bogie type used was HTRB Radial. I don't know what the difference is between them and the ones you mention but there does seem to be differing dimensions depending where you look.
Ron
wsrbloke
Re: wheel centers
Post by wsrbloke » Mon Feb 27, 2023 12:47 pm
Phil P,
On the page I saw for building a 66 they suggested one motor per bogie and delrin chain to connect the other axles. I must say though that was in O gauge but it would work in gauge 1. Alas I didn't bookmark it.
Rn
wsrbloke
Re: wheel centers
Post by wsrbloke » Mon Feb 27, 2023 12:58 pm
Phil.P,
The website is Prototype Replica Model Railway Products . As i said it's 7mm scale but you get the idea.
Ron
