hello,
thanks for this forum. I luckily found an ng16 for sale, un used ,without carton or manual. How does one go about re-guaging the engine from 32 to 45 mm? any help, or insight on this procedure would be appreciated. thank you.
accucraft ng 16 re guaging
Re: accucraft ng 16 re guaging
Hi and welcome.
Not really my forte, but the Accucraft Manual is at http://www.accucraft.uk.com/content/upl ... ARRATT.pdf and the re-gauging intructions are on page 10
- TonyW
With all those wheels, it takes a while. Use Allen key supplied, loosen grub screw, slide wheel down axle, tighten grub screw back in to the drilled hole in the axle.
Check the gas tank too. They were / should have been replaced when the locos were new. You may have to contact Accucraft with the serial number to get a free replacement.
Also, don't expect miracles from it. They all need to have the exhaust piping modified to make them run well. Batch 3 locos (the ones that have the rear engine not superheated and strengthening strips over the cab doors) also need a modification to the lubricator to get optimum performance.
