Roundhouse mk1 Taliesin charging questions.
Simon-m
Post by Simon-m » Sun Apr 10, 2022 6:48 pm
Hi everyone,
I'm looking for a little help please. I've got a mk1 Taliesen & when I got it she had no instructions or charger. As this version has batteries in the tanks I wonder if anyone can tell me what miliamps to charge it at? I'm guessing it's 15 hours charge time?
Cheers
Si
Re: Roundhouse mk1 Taliesin charging questions.
Post by ge_rik » Mon Apr 11, 2022 7:17 am
Simon-m wrote: Sun Apr 10, 2022 6:48 pm Hi everyone,
Cheers
Si
Hi Si
Have you any details on the battery pack voltage. Are they NiMh cells, do you know?
Post by ge_rik » Mon Apr 11, 2022 7:21 am
ge_rik wrote: Mon Apr 11, 2022 7:17 am
Cheers
Si
Hi Si
PS Just found this link to the manual. https://www.manualslib.com/manual/11334 ... e=6#manual
Doesn't indicate a current for charging, what choices does your charger give you?
MRail
Post by MRail » Mon Apr 11, 2022 7:37 am
I have a MKI Taliesin.
There are four AA cells in the tank.
I use a smart charger (Axtronics) 2-12 cells.
Takes about 3hrs to charge.
Rob G
Madog & Mersey Railway (SM32)
TonyW
Post by TonyW » Mon Apr 11, 2022 1:59 pm
siclick33
Post by siclick33 » Mon Apr 11, 2022 3:24 pm
If they are NiCd or Nimh and you want to overnight charge them, then just set the charger on to its lowest mA setting. The more important factors are to ensure that the polarity and voltage are correct. The only time you have to be careful with mA settings is if you want to fast charge.
A 'normal' 4 cell rechargeable battery pack will be 4.8v.
Polarity may be harder to tell (if it has a DC barrel connector). 2 of the biggest RC system manufacturers (Spektrum and Futaba) have different polarity chargers; one has the centre pin of the barrel connector positive, the other negative. If it has a BEC connector (like the one posted in the link in the photo) then the plug can only go in one way and that problem goes away.
Simon-m
Post by Simon-m » Fri Apr 15, 2022 7:54 am
Thanks for the replies everyone. I'm going to give it a go today because I steamed the loco last night & the battery died so it needs a good charge.
Tony I will go with what the strikealite battery says. I thought it would be something like that.
Cheers
Si
Simon-m
Post by Simon-m » Sun Apr 17, 2022 8:39 pm
Tony,
I gave the loco a 15 hour charge at 80ma, runs a treat. Thanks for the help.
Si
