re scale
wsrbloke
re scale
Post by wsrbloke » Wed Mar 16, 2022 4:18 pm
Hi everyone, I would like some info if you can help. I want to print a locomotive in sm32 scale but have to re scale it up from a 00 one and can't work out what percentage it needs to scale up to sm32. Any help will be much appreciated.
Ron
Re: re scale
Post by philipy » Wed Mar 16, 2022 5:07 pm
Assuming that when you say a "00 one" you actually mean 4mm scale and not 3.5mm scale, then to get it to SM32 ( 16mm: ft) you simply multiply everything by 4, ie. 16mm/4mm = 4
wsrbloke
Re: re scale
Post by wsrbloke » Wed Mar 16, 2022 5:22 pm
Thanks, but what is the 4 my printer makes it tiny with that number.
Re: re scale
Post by philipy » Wed Mar 16, 2022 6:08 pm
wsrbloke wrote: Wed Mar 16, 2022 5:22 pm Thanks, but what is the 4 my printer makes it tiny with that number.
Sorry, I'm not understanding?
1ft in real life = 4mm in "00" and 16mm in 16mil/SM32. So if your protoype is 25ft long, the 00 model is 100mm long and in sm32 it will be 400mm long.
Your printer will print it at whatever size your slicer tells it to. What drawing software are you using and what slicer?
Re: re scale
Post by -steves- » Wed Mar 16, 2022 8:03 pm
400 % :thumbup:
wsrbloke
Re: re scale
Post by wsrbloke » Thu Mar 17, 2022 1:57 pm
Thanks Steve, that's more like it.
Ron
