Manual point levers
Manual point levers
Post by ge_rik » Wed Aug 11, 2021 10:42 am
My latest project is to replace my LGB manual point levers with something which looks a bit more realistic. A few bits of brass and a couple of redundant sleepers from a sleeper-strip.
I've blogged the process in case anyone wants to have a go
https://riksrailway.blogspot.com/2021/0 ... evers.html
Re: Manual point levers
Post by Peter Butler » Wed Aug 11, 2021 10:56 am
Very neat job Rik. I'm guessing the blades are not sprung but there seems to be enough weight to hold them in place whilst allowing trains to trail through without derailing?
Post by ge_rik » Wed Aug 11, 2021 11:40 am
Peter Butler wrote: Wed Aug 11, 2021 10:56 am Very neat job Rik. I'm guessing the blades are not sprung but there seems to be enough weight to hold them in place whilst allowing trains to trail through without derailing?
Yes, unsprung. In fact, trailing through switches the blades to the other direction. No doubt, by shifting the positions of the pivot holes in the lever and the plate, it could be made to spring back ...... sounds like a bit more experimentation might be on the cards ...... 😏
Post by Soar Valley Light » Wed Aug 11, 2021 8:21 pm
Very nice Rik - and very realistic too. :thumbup:
SVLR Andrew
Post by Old Man Aaron » Mon Aug 16, 2021 12:46 am
Simple and effective - that screams "narrow gauge". :thumbleft:
GAP
Post by GAP » Mon Aug 16, 2021 4:53 am
Looks real good there Rik would be a good addition to my handmade points.
Consider the idea pinched :D :D
Post by ge_rik » Mon Aug 16, 2021 7:04 am
GAP wrote: Mon Aug 16, 2021 4:53 am Looks real good there Rik would be a good addition to my handmade points.
:thumbup:
Post by ge_rik » Mon Aug 16, 2021 7:08 am
Old Man Aaron wrote: Mon Aug 16, 2021 12:46 am Simple and effective - that screams "narrow gauge". :thumbleft:
I've modified the construction slightly. My thinking is that inverting the bolts puts the nuts on top which look a bit more realistic than the cheese heads.
GAP
Post by GAP » Fri Aug 20, 2021 3:13 am
While procrastinating more over a 3D printer purchase I came across this on the net.
https://www.myminifactory.com/object/3d ... stem-35454
He also has a set of points which could be useful for indoors.
https://www.myminifactory.com/object/3d ... stem-35459
https://www.thingiverse.com/thing:976643
Post by philipy » Fri Aug 20, 2021 6:17 am
Graeme,
"arockstone" is a quite well known SM32/G Scale designer/contributer on Thingiverse, with a range of wagons and track components. Both Rik and I ( and others) have printed versions of his little diesel loco.
Post by ge_rik » Fri Aug 20, 2021 8:25 am
GAP wrote: Fri Aug 20, 2021 3:13 am Rik
Somewhere (possibly Thingiverse), I came across 3d drawings of a double slip in 45mm gauge. I might give it a try sometime.
