Gauge 1 Test track
angr607
Gauge 1 Test track
Post by angr607 » Sat May 08, 2021 11:22 pm
After acquiring some more track from the local model engineering society, I finally replaced my LGB Test track with some proper Gauge One track. Its Cliff Barker Code 180 track which should be ok from a running perspective. I've kept all the LGB just encase because the track isn't exactly laid on flat ground so running could get interesting.
The track is about 6 yards of straight track into a 3 siding area of about 3 yards each. Can't wait to get some stock on here and start testing!
The new siding area including the steaming bay. Which I need to do something proper with. I suspect I'll grab some batton and some screws and screw it and the neighbouring track together. Pretty it won't be but it'll work.
Jon
Current Projects:-
Rebuilding the Railway!
Re: Gauge 1 Test track
Post by ge_rik » Sun May 09, 2021 8:31 am
Love the sweeping curves on the turnouts
