Toby
Toby
Post by -steves- » Mon Jan 18, 2021 6:41 pm
I decided to have a go at designing and printing a "Toby" type tram from the old Wisbech and Upwell line. I know it's been kitted a few times before, but not by me and I too stingy to buy a kit when I have free CAD software and a 3D printer.
Anyway, my first thing was to try and design and print the cow catcher, needs a bit of modifying, but looks like it is possible to do.
Re: Toby
Post by philipy » Mon Jan 18, 2021 7:58 pm
That doesn't look too bad at all.
I've often thought about doing a tram loco but never got around to it, so will follow this closely.
Re: Toby
Post by -steves- » Mon Jan 18, 2021 9:27 pm
philipy wrote: Mon Jan 18, 2021 7:58 pm That doesn't look too bad at all.
That was my thoughts exactly before I started it. Spent too many years wanting one and no time to build one. I had the plans half done many years ago,well more like started them rather than half done, lol.
Re: Toby
Post by -steves- » Tue Jan 19, 2021 12:23 pm
Well I have the main body, skirts and cow catchers all done in CAD, just have to work on all the accessories now like bell, hand rails etc now.
Re: Toby
Post by ge_rik » Tue Jan 19, 2021 12:55 pm
Very nice! As a great fan of the Great Eastern, I thoroughly approve ..... :salute: :thumbup:
Re: Toby
Post by -steves- » Tue Jan 19, 2021 1:10 pm
ge_rik wrote: Tue Jan 19, 2021 12:55 pm Very nice! As a great fan of the Great Eastern, I thoroughly approve ..... :salute: :thumbup:
Awesome :thumbup:
I did reach the limits of Tinkercad on this one, a "circle" can only have 64 sides max and once at that kind of size it's noticeable. It has come out rather hexacontatetragon shape so in this case you can see the sides about every 10mm. Not a problem, this particular tram had a wood roof and that happens to be the exact size that as the planks of wood originally used, lol. (Well that's my excuse and I am sticking to it). :mrgreen:
I have started printing the various bits, but it says it will take around 2 days (plus stoppage time overnight) to print them all :shock:
Re: Toby
Post by philipy » Tue Jan 19, 2021 1:41 pm
Looking good. How many print parts are there? i.e stl's
What are you doing about chassis etc? I assume you'll build your own frames but what about motor, gears etc?
Re: Toby
Post by -steves- » Tue Jan 19, 2021 3:26 pm
philipy wrote: Tue Jan 19, 2021 1:41 pm Looking good. How many print parts are there? i.e stl's
The chassis will be the same ones as I usually do. In design similar to the GRS and the Essel ones, though all the dimensions differ between all 3 as do the materials as I love the weight of brass :D Generally my chassis are so heavy that it doesn't matter how light the body is, it still has immense pulling power. I use the Como Drills motors with the built in gearboxes, usually the 15:1 for speed and 30:1 for a more realistic line speed. I use standard 4mm bore nylon bevel gears, but drill one of them out and then make a brass insert that reduces the width of the gear enabling me to set the wheel gauge to either 32mm or 45mm. GRS sell one very similar but they use the gears as standard and therefore have to have different wheels for 32mm and 45mm and therefore sell you either a 32mm chassis or a 45mm chassis. Essel I think cut their own smaller gears from brass enabling them to do a dual gauge chassis. Actually thinking about it, I have a spare Essel chassi kicking around so I might just use that and add some weight. :thumbup:
Re: Toby
Post by philipy » Tue Jan 19, 2021 3:41 pm
Thanks. I guessed it would be something along those lines. :D
Re: Toby
Post by -steves- » Wed Jan 20, 2021 2:31 pm
I have finally finished the design and the accessories, just have to wait and how it all prints off and any changes required.
tram 3d shot complete.JPG (64.53 KiB) Viewed 8275 times
Re: Toby
Post by -steves- » Fri Jan 22, 2021 5:42 pm
Well I managed to get all of the main panels printed and put together. I also managed to dig out an old essel chassis and make some plates up to attach it to the chassis. I made a couple of brass stations to go from the floor to hold the roof on, threaded top and bottom for screws and happy with the result so far.
Re: Toby
Post by -steves- » Fri Jan 22, 2021 5:44 pm
underside and inside at the moment
Re: Toby
Post by philipy » Fri Jan 22, 2021 7:14 pm
That looks excellent Steve.
Re: Toby
Post by FWLR » Sat Jan 23, 2021 7:35 am
Fabulous Steve, that does look good. Wish I had your skills in CAD, but alas.... :roll:
Re: Toby
Post by Andrew » Sat Jan 23, 2021 11:01 am
Very nice! I've got a soft spot for the GER trams too - I've got one in OO that my Dad built from a kit.
As I recall, when The Fat Controller acquired Toby he decided the BR livery was a little drab - does he end up with blue skirts? I'll be interested to see what livery you go for Steve - and whether Henrietta's next?!
And don't worry Rod, you'll get there - you've not had your printer a month yet, practice makes perfect!
Re: Toby
Post by -steves- » Sat Jan 30, 2021 5:17 pm
A bit of an update, still got the weathering to do, some windows to do, the bell wire and maybe outline the window frames in white, not sure yet, but happy with it so far. :thumbup:
Re: Toby
Post by philipy » Sat Jan 30, 2021 6:14 pm
Superb.
Re: Toby
Post by ge_rik » Sun Jan 31, 2021 8:24 am
Impressive!
Re: Toby
Post by FWLR » Mon Feb 01, 2021 8:25 am
That looks a lot like Anne's Perfect World Tram. Nice...
Re: Toby
Post by -steves- » Wed Feb 03, 2021 1:51 pm
Well I am nearly finished, just needs some handrails and a coat or two of varnish. Had it on a test run this morning :thumbup:
