Putting the garden into the railway
GAP
Post by GAP » Wed Apr 29, 2020 4:10 am
After building the elevated railway I planted out under it to fill in the under space, bit of the opposite way to most layout builds in that the track went in before the garden.
I have used shrubs that should grow to the top of the fence and will spill out between the upper and lower levels.
I planted a couple behind the trestles they will hide the big black pot and give a leafy background to the high trestle.
The plants are called Acalypha and are a tropical plant that are used for hedging but grown mostly for their colourful leaves.
Re: Putting the garden into the railway
Post by LNR » Wed Apr 29, 2020 5:14 am
That's how I did Mine on the raised section, track first and then plant underneath, the original intention being to keep it just above track level. Now however, track is running through a forest !!
Timber train 2.JPG (165.91 KiB) Viewed 61376 times
Constant pruning beat me in the end.
GAP
Post by GAP » Wed Apr 29, 2020 9:04 am
LNR wrote: Wed Apr 29, 2020 5:14 am That's how I did Mine on the raised section, track first and then plant underneath, the original intention being to keep it just above track level. Now however, track is running through a forest !!
That is the effect I am aiming for.
Post by ge_rik » Wed Apr 29, 2020 12:32 pm
By contrast, I started with a hedge and built the railway into it. Same end result, different route.
GAP
Post by GAP » Wed Apr 29, 2020 10:14 pm
Grant
What plants did you use?
Post by LNR » Thu Apr 30, 2020 1:36 am
GAP wrote: Wed Apr 29, 2020 10:14 pm Grant
The one nearest the camera with the paler green leaves is Orange Jessamine or Satinwood ( Murraya paniculata ) and I notice that it is native to Nth. Queensland. It has larger leaves. The further one is Sunset Lillypilly (Syzygium Australe ) has much smaller leaves and grows like hell!
GAP
Post by GAP » Thu Apr 30, 2020 4:33 am
Murraya paniculate also know as "Mock Orange".
In the pictures in the link to my blog below the plant seen looking straight out the shed is one, I had cut it back before the picture was taken.
https://ringbalin-light-railway.blogspot.com/2019/08/
It was removed along with a tree to make way for the railway, the tree remover told me that cutting mock orange ruins chainsaw blades quote It's like cutting wire rope".
