Accucraft Ragleth - fitting RC
SVLR
Post by SVLR » Sun Apr 19, 2020 7:06 pm
I have at last got around to having a go at phase 1 conversion ie basic single servo just on the forward-reverse lever. I have taken the body off and almost finished the servo mounts. My question is (and I have looked around for an answer) is how do you stop it locking in position? I am thinking its a case of removing the spring. Any advice, pictures videos, weblinks that would help would be very much appreciated.
Puddlejumper
Re: Accucraft Ragleth - fitting RC
Post by Puddlejumper » Sun Apr 19, 2020 7:15 pm
Could you describe how you have done this?
I have an Edrig that has RC on the regulator and I’d like to add a servo to the reverser if possible.
Many thanks
Doug
Post by Chris Cairns » Sun Apr 19, 2020 9:04 pm
The forward, neutral & reverse positions of the reverser lever are fixed using an M2 bolt which goes into the appropriate slot.
Accucraft Ragleth 06B.jpg (107.77 KiB) Viewed 7303 times
So either unscrew or fully remove that M2 bolt. Job Done.
Post by tom_tom_go » Sun Apr 19, 2020 9:16 pm
I did the same as Chris when I had a Ragleth:
https://gardenrails.org/forum/viewtopic ... h&start=30
SVLR
Post by SVLR » Sun Apr 19, 2020 10:16 pm
Chris Cairns wrote: Sun Apr 19, 2020 9:04 pm The forward, neutral & reverse positions of the reverser lever are fixed using an M2 bolt which goes into the appropriate slot.
That was so easy (and so obvious when I realised duh!) Thanks for the tip Chris,
Puddlejumper
Post by Puddlejumper » Mon Apr 20, 2020 8:21 am
Thank you for that, it’s looks much simpler than I thought it was going to be. :thumbleft:
