My First Loco Recommendations Please
Hello everyone I am looking to buy/make my 1st loco and since I am now on very tight budget due to buying some 45mm track and my car breaking down this week I thought I would get some recommendations.
I know can try and find a cheap Playmobil loco if I am lucky but I have also been looking at one of these kits
https://www.ebay.co.uk/itm/16mm-SM32-or ... %7Ciid%3A1
I don't know if they are any good (I mean no disrespect to the seller) but I don't know if they can be battery powered or what their pulling power is like. So if nayone has any knowledge of these or has any other suggestions I would be most grateful for your input
Re: My First Loco Recommendations Please
Hi and welcome.
No experience of the seller, however, at that price you cannot really complain if it does not meet your expectations.
IP Engineering are a well known supplier of budget garden railway stock:
https://www.ipenginnering.com/
No, I haven't spelt the web address wrong that is what they are currently using.
I have some experience of these kits, one which I built for a friend and another I was asked to finish by fitting RC gear etc. (I sent that one back to its owner!) In both cases I wasn't impressed with the kits, not that they are poorly designed and printed, rather that they are made of flimsy, lightweight material which will last about a week! The build itself is also not simple and edges are exposed and unfinished.
Elsewhere, others have noticed the colour change when exposed to daylight.... that's where a garden railway is usually sited.
Save your money for something more substantial, or just buy a chassis and build your own body, by far the best option.
Try to get something with metal (not plastic) wheels and four wheel drive. 3v motors (as usually supplied with budget chassis) have no pulling power whatsoever and can't be improved by adding much needed weight.
I am currently building a PDF (3D printed) Hunslet kit and it is very well designed and manufactured and just needs battery to finish. You can have a 12v motor as an option which will give extra power and longer running. It does however need a lot of preparation for a nice paint finish, but worth the effort.
I'm sure there will be other (more useful) advice given so carry on saving for a while.
- Busted Bricks
That would be my recommendation as well. Easy to build and robust with a decent mechanism.Busted Bricks wrote: ↑Wed Feb 12, 2020 5:15 pm For the money you really can't go wrong with a loco kit from HGLW.
http://www.hglw.co.uk/Locos.html
I wrote up my build of one of their locos here.... https://riksrailway.blogspot.com/2018/0 ... t-and.html
I've also added Deltang RC and an Acme soundcard
PS
If you don't mind using your phone or tablet as a transmitter, you could cut costs the control system by using one of these http://locoremote.co.uk/
I second the recommendations for IP Engineering and HGLW - we have laser cut kit locos from both on our line and are very happy with them.
Phil Sharples also does a few laser cut loco kits, e.g: https://www.ebay.co.uk/itm/Sm32-Sm45-16 ... 3340227699
- BorisSpencer
+1 for HGLW excellent budget kits, and a massive +10 for PS models, loads of lovely simple to build kits which you can improve upon with your own detailing.
The PS kit linked above above will not disappoint. It won't pull a rake of loaded tippers, but will manage adequately pulling half a dozen of Phil's wagons.
Thanks for your reply and the web addresstom_tom_go wrote: ↑Wed Feb 12, 2020 4:07 pm Hi and welcome.
Thank you so much for the advice as the last thing I want is something too flimsy I will go and have a look at the Hunslet kit I recall seeing one somewhere but will recheckPeter Butler wrote: ↑Wed Feb 12, 2020 4:12 pm I have some experience of these kits, one which I built for a friend and another I was asked to finish by fitting RC gear etc. (I sent that one back to its owner!) In both cases I wasn't impressed with the kits, not that they are poorly designed and printed, rather that they are made of flimsy, lightweight material which will last about a week! The build itself is also not simple and edges are exposed and unfinished.
Wow!! they look quite impressive I will go and read a little more on their website. Thank you very much for the infoBusted Bricks wrote: ↑Wed Feb 12, 2020 5:15 pm For the money you really can't go wrong with a loco kit from HGLW.
That is brilliant Thank you. I have just had a quick read of your website its very good and look forward to reading more and watching your videosge_rik wrote: ↑Wed Feb 12, 2020 6:46 pmThat would be my recommendation as well. Easy to build and robust with a decent mechanism.Busted Bricks wrote: ↑Wed Feb 12, 2020 5:15 pm For the money you really can't go wrong with a loco kit from HGLW.
I Like this and thanks for the heads up will definitely consider this at a later pointge_rik wrote: ↑Wed Feb 12, 2020 7:16 pm PS
Thank you for you inputmetalmuncher wrote: ↑Wed Feb 12, 2020 7:28 pm I second the recommendations for IP Engineering and HGLW - we have laser cut kit locos from both on our line and are very happy with them.
Thank you for the advice I will have a look at this PS kits too as well via the ebay linkBorisSpencer wrote: ↑Wed Feb 12, 2020 9:06 pm +1 for HGLW excellent budget kits, and a massive +10 for PS models, loads of lovely simple to build kits which you can improve upon with your own detailing.
HGLW, PFD Models, IP engineering and Phil Sharples are all excellent producers of nice inexpensive kits and are all really well produced. There are also smaller producers for rolling stock that are also very good.
You really get want you pay for, though with care, all of the sellers kits can be a model to be proud of.
Good luck in your journey in garden railways. It's a fantastic hobby and you won't go wrong with all the valuable knowledge and expertise on the forum. And there are some excellent Blogs on here, you have already perused ge_rik's Blog. I would advise reading has much as you can of his Blog, he as more or less made it easy for new and experienced 16mmillers to build and run their garden railways.
PS. There are other Bloggers on here...
Hope I'm not too late!
I have experience with Swift Sixteen, IP engineering and PDF models. All 3 are good, PDF models now supply metal frames and motion with their models (I'd check before buying, it makes a difference).
Of the 3; Swift Sixteen provides the highest quality model although the kits are slightly more expensive; Robs Tin turtles are definitely comparable to a Roundhouse Little John though!
IP provide good quality wooden, plastic and pewter models at a relatively good price. Ivan is very helpful and prompt.
PDF is also a good choice, I have a Fairlie kit that's currently being made. 3D printed parts will require a lot of work though to get a good finish! Peter has a Facebook group if you have Facebook (I don't anymore but I used to be part of it, it was a good group).
If you have a slightly larger budget; Essel Engineering...
Thank you for that it is my first Garden Railway I did have a hornby 00 gauge layout many many years ago but it seems like chalk & cheese as a comparison lol so I an very grateful to everyone who has repliedFWLR wrote: ↑Thu Feb 13, 2020 8:39 am HGLW, PFD Models, IP engineering and Phil Sharples are all excellent producers of nice inexpensive kits and are all really well produced. There are also smaller producers for rolling stock that are also very good.
Thanks for the information and advice not sure I am not getting email updates at present otherwise I would have replied sooner. So your advice is neither late and is definitely welcome. I just looked at the Essel Engineering website ( I like the shunter's on the homepage) sadly i am no where on budget at present ( dam car!!) but I will take your advice on board and use it as I re- read all the mentioned sitesJMORG wrote: ↑Thu Feb 13, 2020 5:37 pm Hope I'm not too late!
