Tralee & Dingle cattle wagon
Who says there are no bargains at GR Fairs these days? I picked up this rather magnificent model at Llanfair on the Sunday for the princely sum of £20.
I was told it was a 10mm scale model of a Tralee & Dingle cattle wagon. It was 32mm gauge but I felt it would be relatively easy to regauge and re-wheel which turned out to be so.
It's slightly over-sized in comparison with my homebuilt W&LLR cattle wagon, but to my mind not noticeably so. It's beautifully constructed in wood with plenty of wonderful details. Any ideas if it's a scratchbuild or made from a kit??? I would certainly be happy to have another to keep it company if it is a kit.
- Lonsdaler
Re: Tralee & Dingle cattle wagon
Blimey! £90 seems steep, especially for IP stuff? Better start saving up Rik.tom_tom_go wrote: Mon Sep 23, 2019 3:28 pm Possibly an IP Engineering kit?
https://www.ipenginnering.com/product-p ... -wagon-kit
I don't think it's the IP kit. That has a lot of brake gear detail which this model lacks - unless the builder decided not to bother constructing those details which seems odd given the amount of effort which has gone into the bodywork.
PS - Yes, I blanched at the thought of forking out £90 for just one wagon. I think my entire rake of nine Snailbeach tipplers cost about that to construct - but then they're not as highly detailed!
- GTB
The universe is full of coincidences, I found a copy of Dave Rowlands book 'The Dingle Train' in a local bookshop for much the same money last week........ge_rik wrote: Mon Sep 23, 2019 3:12 pm Who says there are no bargains at GR Fairs these days? I picked up this rather magnificent model at Llanfair on the Sunday for the princely sum of £20.
The model is nicely made, but I do hope there is a tin of grey paint with it's name on it somewhere.
The model looks a bit big to be a 10mm scale model. FWIW, the drawing of a Dingle Pickering cattle wagon gives the body dimensions as 14’6” long, by 6’6” wide and 9’ high from rail level. Unless Welsh cows are markedly smaller than than the ones on the other side of the Irish sea, a T&D cattle wagon should be around the same size as a W&L one, just a bit wider.
- BorisSpencer
Comparing your photos with the one on the IP site, I agree they're not quite the same, but they certainly share the same prototype.
There's a lot of strapping detail on there, but if you went for a shallower relief like the IP photo, I would suggest they're ripe for a resin casting like you used for some of your early wagons. (I never forget anything I've read in your blog!).
