Point radius?
- pandsrowe
Point radius?
With all the discussions that have been taking place recently on track gauges and the like, it has brought to my attention that a lot of people refer to radii as R1, R2 etc. Excuse my ignorance but can anyone tell me what these radii actually are?
- GTB
Re: Point radius?
The use of R1, R2, R3 and R5 to describe the curvature of set track originated with LGB and is now used by other G scale manufacturers to describe their set track curves. To confuse english speakers, the catalog quotes the diameter of the curves in mm, which is quoted as centre to centre and also outer rail to outer rail for some reason.......pandsrowe wrote: Fri Aug 16, 2019 10:04 am With all the discussions that have been taking place recently on track gauges and the like, it has brought to my attention that a lot of people refer to radii as R1, R2 etc. Excuse my ignorance but can anyone tell me what these radii actually are?
https://www.lgb.com/fileadmin/media/lgb ... m-Info.pdf
R1 is a radius of 600mm
R2 is a radius of 780mm
R3 is a radius of 1195mm
R5 is a radius of 2320mm
For the non-metricated they are roughly equivalent to 2’, 2’6”, 4’ and 7’6” radius curves.
I own exactly four pieces of LGB track. Two double straights and two R3 curves, that I use on the workbench to test that new models will negotiate a minimum 4’ radius reverse curve, which is my design standard.
idlemarvel
Re: Point radius?
Graeme is correct as far as LGB is concerned, however other manufacturers of code 332 track use the same names for different radii.
R1 tends to be universal (600mm) but for example PIKO R3 is 922mm not 1195mm. The other manufacturers (Train-Line 45, Aristo-Craft, there may be others) have their own differences. Someone on gscalecentral attempted to produce a table of all these set track curves, I'll see if I can find a link.
DonW
Re: Point radius?
THe Peco G scale turnout is advertised as medium radius 1219mm
Don
Don
Re: Point radius?
Point and radius have been a bug bare of mine since I started building layouts in N Gauge and it hasn't improved with 16mm.....
Since generally most people use Peco track, I know there are others. I have just been on Peco's website and this is what their information is on their points..
Medium...
https://peco-uk.com/collections/sm-32-3 ... 4231325730
Small...
Has they only provide information on R1 and R2 curves, this is all you will find on the site.
R1...
https://peco-uk.com/collections/sm-32-3 ... 5690868770
R2...
This is of course ready made track, I wouldn't have the foggiest on where to get and buy other radius points and curves. There is of course Flexitrack, but that's a different art in its self. It is for me anyway....
Medium...
Small...
R1...
R2...
Re: Point radius?
Sorry, I didn't do 45mm. So here are the links.
Small radius point....Their description is not correct, but you will soon realise that it's the smaller radius....
https://peco-uk.com/products/turnout-me ... 4231325730
This is the Medium...
https://peco-uk.com/products/turnout-me ... 5750932514
They only do one curve....
https://peco-uk.com/products/standard-c ... 5745361954
One thing though and it's has I thought, there is a vast difference in price for 45mm, compared to 32mm. I also know it's on Peco's own website, but I assume there is a difference where ever you buy from.
- pandsrowe
Re: Point radius?
Apologies for the delay in responding but thanks to you all for the explanations. I think from my perspective I will continue to describe radii as "x", there seems to be too many variables in using the "Rx" system.
