Wadebridge Light Railway
- steamgeorge
Hi all,
I am relatively new to the hobby and forum. In late 2016, after about a year and a half of initial ideas and planning, construction started on my first garden railway! Track gauge was decided to be 32mm to a scale of 16mm to the foot. The track would be peco sm32 laid on a floating trackbed of alpine grit. I will upload some photos one I figure to how to.
Re: Wadebridge Light Railway
Hi George and welcome!
Please check the forum help section for posting pictures.
Welcome aboard, George. Looking forward to seeing the photos.
- IanC
Welcome to the forum. Yes, please post some pictures. It,s quite easy to do. Just remember not to have the file size too big.
- steamgeorge
Here are photos of the 'first chapter' of my railway. there are more to come as the line was extended.
your thoughts would be appreciated. George
- Attachments
- the first sod
- IMG_20160501_181701866.jpeg (424.28 KiB) Viewed 31027 times
- membrane, ballast and the first track laid
- IMG_20161110_101908760.jpeg (406.41 KiB) Viewed 31027 times
- the loop (almost) complete
- IMG_20161215_080223747.jpeg (339.33 KiB) Viewed 31027 times
- landscaping taking place
- IMG_20170226_154115708.jpeg (433.22 KiB) Viewed 31027 times
- new arrival: A roundhouse millie. My first controllable loco!
- IMG_20170226_174310456.jpeg (293.44 KiB) Viewed 31027 times
- the pw department yard
- IMG_20170316_175446177.jpeg (217.44 KiB) Viewed 31027 times
- The engine line up
- IMG_20170319_173456089.jpeg (318.07 KiB) Viewed 31027 times
- The first ever passenger train
- IMG_20170520_103807669.jpeg (329 KiB) Viewed 31027 times
- Work starts on Delabole quarry
- IMG_20170804_133158473.jpeg (420.22 KiB) Viewed 31027 times
- IMG_20170804_200112557.jpeg (369.79 KiB) Viewed 31027 times
- the loop taking shape with plants settling in
- IMG_20170804_200155660.jpeg (297.14 KiB) Viewed 31027 times
- a new arrival: a Cheddar Iver. A delightful engine and also our first RC.
- IMG_20170928_164049788.jpeg (312.6 KiB) Viewed 31027 times
- The quarry progressing well
- IMG_20171116_160027780.jpeg (240.35 KiB) Viewed 31027 times
- IMG_20171116_160118037.jpeg (277.16 KiB) Viewed 31027 times
- the loop
- IMG_20171220_133500190.jpeg (429.42 KiB) Viewed 31027 times
- next to the quarry
- IMG_20171220_133523748.jpeg (382.1 KiB) Viewed 31027 times
- steamgeorge
unfortunately they turned out in the opposite order that I intended them to be but it should make sense if you read from the end
- Soar Valley Light
Hello George,
Thanks for posting the pictures. Your line is clearly well engineered. The track geometry is very nice (I can't help notice - it's one of my obsessions!). Getting that right creates a far more realistic appearance than track just thrown down with the excuse that 'narrow gauge lines were like that". Most lines, even industrial ones, were properly designed, set out and built at their birth. Your sidings and wagon turntables linking them look really good.
Super job!
Super job!
- steamgeorge
Andrew, that area of the railway has changed significantly over the past year, you will be able to see the change in upcoming photos. In the meantime, check out me youtube (Wadebridge Light Railway Company) to see some videos of my line. Thank you for your kind comments
George
George
- steamgeorge
This is the difference
- Attachments
- this is a fairly recent photo of the railway (august 2018)
- IMG_2682.jpeg (174.67 KiB) Viewed 31006 times
IrishPeter
Cracking job, George! Very nice little railway.
Peter in Va
Peter in Va
Welcome aboard George. That's a cracking railway to start your introduction
I do love that little turntable, I wish I had taken the time to build one at the end of my run round loop. As Andrew said good planning and engineering pays off, as Mr Impatient I can vouch for that...
That's looking lovely, thanks for the photos!
Great looking line and well worth the effort. Like both Andrewβs have said, β Planning it right is always the best way β Although most of us just go with the flow if you get my meaning George.
I am in the same mould has bazzer42, and I now have to take more time doing things myself.
Can you put some of you videos onto the forum mate, it would be easier for some of our members to get to see them.
Keep up the excellent work George.
- steamgeorge
Here is a link for a video of my Dads cheddar Iver:
https://www.youtube.com/watch?v=_D6CKEMIYM8
Over the course of this year I have been busy extending the railway. A much larger loop (still small) has been constructed around the garden and joins up to the circle of track seen in previous posts. This allows the railway to be run as a figure of 8. Also, there are 2 passing loops on the larger loop with a similar running distance between the two. This has provided very useful because 2 trains can run in opposite directions. There will be a station at each passing loop; one is Port Isaac Road and the other is St Kew Highway. Here are some photos of construction.
- Attachments
- overall view of one half of the railway
- IMG_2688.jpeg (185.53 KiB) Viewed 30901 times
- the track is down!
- IMG_2687.jpeg (172.27 KiB) Viewed 30901 times
- a train can now be run the opposite way out of St Kew Highway
- IMG_2686.jpeg (165.08 KiB) Viewed 30901 times
- planning Port Isaac Road
- IMG_2685.jpeg (200.66 KiB) Viewed 30901 times
- constructing the stone 'walls' to retain the ballast for the section of line across the path. the concrete is to the ratio 4:1 and is fixed to a foundation of packed hardcore
- IMG_2684.jpeg (209.87 KiB) Viewed 30901 times
- trench for the trackbed leading to the path
- IMG_20180719_122615232.jpeg (131.9 KiB) Viewed 30901 times
- track laid up to Port Isaac Road
- IMG_2529.jpeg (177.34 KiB) Viewed 30901 times
- steamgeorge
There is still a lot of work to do but at least the line is up and running. I will post more about the lines fictional history in a later post.
Thank you for all the comments.
George
George
- pandsrowe
One thing that certainly impresses me with your railway is the nice neat edges between the trackbed and the grass. If that was in my garden the blackbirds would have thrown half of the ballast onto the grass in their search for food and the cat would have dislodged the remainder as he used it as a litter tray, you must spend an awful lot of time in maintaining the pristine look!
Put it on here George for everyone to see.
Thanks for the link. It is very easy to put it on yourself though, Just click the video box and move in-between the two video boxes that comes up and then paste the video. It then will show the video without going onto Youtube.
Nice loco and rolling stock by the way.
- steamgeorge
Thank you Pandsrowe, I am pleased you appreciate how much effort goes into maintaining a line with loose ballast. Unfortunately, a neighbours cat uses the railway as a litter tray . However, as the railway progresses, more areas of ballast will be covered up which should help. I am thinking of securing the ballast down with tile adhesive as well.pandsrowe wrote: Sun Sep 30, 2018 7:57 am One thing that certainly impresses me with your railway is the nice neat edges between the trackbed and the grass. If that was in my garden the blackbirds would have thrown half of the ballast onto the grass in their search for food and the cat would have dislodged the remainder as he used it as a litter tray, you must spend an awful lot of time in maintaining the pristine look!
- steamgeorge
A bit of progress yesterday, I have finally got round to making the platform at St Kew Highway. It is made of concrete and reflects many narrow gauge lines as it is only level with the top of the sleepers. There will be a water tower, lamp hut, station building, benches etc on it once I get round to building them. I have also posted some pictures of Trethevan halt crossing as this was started a few weeks ago. There is still a lot of work to do though including actually building the halt!
- Attachments
- close up of the level crossing
- IMG_20180930_120111603.jpeg (275.48 KiB) Viewed 29278 times
- Trethevan halt
- IMG_20180930_120100042.jpeg (363.2 KiB) Viewed 29278 times
- the platform
- IMG_20180930_115937299.jpeg (404.63 KiB) Viewed 29278 times
- unfortunately I ran out of sand just before I could complete to south side of the station
- IMG_20180930_120038700.jpeg (372.25 KiB) Viewed 29278 times
Nice job George.
