Roundhouse sight glass leaking
Post by tom_tom_go » Sat Sep 08, 2018 1:24 pm
Noticed this today, water dribbles from the bottom of the gauge (the metal surround plate is removed to show the leak):
It only leaks when there is pressure in the boiler.
Can I repair it, does it just need descaling?
Re: Roundhouse sight glass leaking
Post by tom_tom_go » Sun Sep 09, 2018 10:42 am
Cleaned it last night (the glass panel just pops out) but this morning even with no pressure in the boiler it still leaks.
I have emailed Roundhouse, odd one this.
Post by Big Jim » Mon Sep 10, 2018 7:26 pm
Is there a paper gasket or is it an o ring?
Post by tom_tom_go » Tue Sep 11, 2018 9:36 am
No seal as far as I can see so I made a gasket from coffee filter paper and seems to have fixed it for now.
I will see what Roundhouse say when they email me back.
IanC
Post by IanC » Tue Sep 11, 2018 11:58 am
Interesting to see that no one has offered any advice or a solution. None of my locos have a sight glass so I've not had the problem. My only thought would be to use a smear of silicone sealant. On the full sized locos the gauges often weep a little. However that can sometimes be cured by tightening up by hand, the two securing nuts at the top and bottom of the water tube. It only takes the slightest of adjustment. They are also changed after 21 steamings as a precaution against them breaking in traffic.
Post by Big Jim » Tue Sep 11, 2018 12:32 pm
I am surprised that there is no seal on the gauge. A weep under pressure and then a leak when could would suggest to me a failed gasket .
Not having a loco with a glass like that I can't dismantle one to have a look.
I agree with Ian that a smear of silicone may be belt and braces.
Just out of interest, have you had the glass out or just put the gasket between the two brass mating surfaces?
Post by tom_tom_go » Tue Sep 11, 2018 6:59 pm
The gasket I made is wedged between the steel plate and the sight glass.
Mr Roundhouse is sending me a new seal so when I get it I can work out what and where it is located!
gilfachphil
Post by gilfachphil » Thu Oct 16, 2025 11:08 am
Now you know!
I am investigating the same issue years later. This is the gasket:-
It is underneath the glass in a machined slot around the edges of the aperture.
I'm waiting on hearing back from Roundhouse about getting hold of a couple.
My layout thread:-
viewtopic.php?t=13912
MRail
Post by MRail » Wed Oct 29, 2025 1:29 pm
Friend is having a leak problem with a similar gauge on a VoR loco.
Obviously it's a few years old.
He's broken one screw trying to tighten it in hope of stopping the leak.
Coming to me to extract the broken piece and salvage the assembly.
I'm wondering if anyone knows the screw size? I'm guessing 10BA, or perhaps 8BA?
Don't really want to dismantle my own loco to find out!
Thanks,
Rob G (Mrail)
Merseyside
Rob G
Madog & Mersey Railway (SM32)
Preseli Chris
Post by Preseli Chris » Wed Oct 29, 2025 11:36 pm
Contact Roundhouse. They would know and be able to supply a replacement. They do provide a good backup service.
Yr Tren Nesa Wedi Mynd
MRail
Post by MRail » Thu Oct 30, 2025 10:30 am
Thanks, but been there, done that.
No definitive info, but did send a selection of screws.
He's trying to reassemble with broken screw.
I await report.
Rob G
gilfachphil
Post by gilfachphil » Fri Oct 31, 2025 6:36 pm
Preseli Chris wrote: Wed Oct 29, 2025 11:36 pm Contact Roundhouse. They would know and be able to supply a replacement. They do provide a good backup service.
I second that.
Having emailed Roundhouse and not received a reply I eventually got round to phoning them. Spoke to a very helpful guy who told me that the water gauge had used three different sizes of O rings over the years and offered to post me one of each for my Silver Lady.
Don’t be shy, give them a call, it works,
My layout thread:-
