My Railway is nominally set with minimum radius curves of 38 inches. This is fine for my stock and locos, and all can negotiate the track without problems. However, when others come to run on my line, a couple of the curves, whilst, as I said, nominally 38 inches, obviously only
average 38 inches, with two spots in particular where the curve is much sharper!
An additional problem is that all my ballast is fixed down with SBR, and that seems to be almost 'permanent' once set. however, this weekend I have decided to address the most troublesome tight spot, near my bridge.
Removing ballast set in SBR
This was actually easier than I feared. It did require the use of a chisel (I use an old 1" wood chisel, rather than a 'cold' chisel). Using this it was possible to release the track from the paved area in question. Once the track (peco, in my case) was lifted, it was relatively easy to pick it clean of residual ballast and dried SBR. So the good news is that SBR is a good fixative, being very solid and hardwearing once dried, but it can be removed if needed.
Track Re-alignment
This photo shows the old alignment of the curve (I forgot to get a before picture
) with the old permanent way removed and the new alignment in place.
- Bridge-curve-re-alignment1.jpg (327.34 KiB) Viewed 8154 times
I used a metre rule pegged at the axis of the radius to gauge my curve (with the aim of keeping to 39 1/2 inch radius). This composite photo shows the ruler being laid against the curve.
- Bridge-curve-re-alignment3.jpg (330.03 KiB) Viewed 8154 times
I also took the opportunity move a short radius 38" point (switch) further from the curve in question, and replace it with a 60" radius point instead.
- Bridge-curve-re-alignment2.jpg (325.27 KiB) Viewed 8154 times
The result is a much smoother curve, even for my stock, and a less ferocious transition from the point, where there was a nasty reverse curve, which also caused some problems. The only issue with this is that it has drastically shortened the passing loop, so similar replacement will take place at the other end, but further down, to restore the loop length.
All I need to do then is reballast - it's surprising how 'flimsy' the permanent way is before the ballast is fixed.
And this will also leave me with 2 short radius points - for which I have a cunning plan...
