IP wagon scale
- JMORG
IP wagon scale
Hi all,
I'm currently looking at getting some NWNGR/WHR wagons for our growing collection of WHR stock (Fairlie, Baldwin and eventually Welsh Pony).
Looking at both the IP kits and the Bernard Rockett book seems to show quite a large discrepancy in regards to dimensions; IP apparently use J. C. Boyd's notes, although I am well aware of the errors Boyd unfortunately used to make in his books.
If any WHR fanatics are able to help that would be great!
- River Lin
Re: IP wagon scale
Hi.
I draw out my own plans for making my NWNG stock. One method I use is to find a photo of an end view. Using the rail gauge as 2 foot I can work out the width and height and other details. From a side view photo, if I know the height I can work out the length and window and door dimensions etc.
D.
D.
David T.
- JMORG
Re: IP wagon scale
Cheers David,
Trouble is, some of the WHR vans are quite camera shy. I'd rather not use the current replica's on the WHHR due to them being modified from ex RNAD wagons.
The brake vans in particular are what I am after.
- River Lin
Re: IP wagon scale
Hi.
If you can get yourself a copy of 'Wheelers Day' published by the Welsh Highland Heritage Group you will see some superb shots of WHR goods stock between pages 46 - 50 taken in situ in 1935 including brake van number 2. No sizes I'm afraid though.
I am currently in the process of sorting out plans to build this van but one has to be careful about information you find. I am using the 'Rockett' book as inspiration where this Wheeler photo of No 2 is also reproduced but have noticed that he, or his publisher has labelled the end views incorrectly. No2 does not have vertical wooden framing between the windows as is shown by the Wheeler photo.
As far as sizes are concerned, Rockettes states van No2 as 10ft 3in long and 5ft 9in wide whereas Boyd gives approx. 11ft long by 5ft wide.
Now I appreciate authors try to be as accurate as they can to help modellers like ourselves but we also have to make our own decisions. Neither of the two old brake vans escaped the flames to remove the scrap ironwork so it is up to us to interpret as we think fit. If my version is slightly different in size to someone else's it doesn't matter. We will both have had the satisfaction of doing what we enjoy to produce a lovely model.
D.
D.
David T.
- JMORG
Re: IP wagon scale
Well put David, basically just show's I'm being too much of an anorak and I should just get on with it!If my version is slightly different in size to someone else's it doesn't matter.
- IanC
Re: IP wagon scale
Does Rule 1 apply? It's your railway? If the definitive answer isn't public, who's going to tell you your wagons are wrong?JMORG wrote: Thu May 03, 2018 10:41 pmWell put David, basically just show's I'm being too much of an anorak and I should just get on with it!If my version is slightly different in size to someone else's it doesn't matter.
Press on with your build I'd say.
