Side cutters - which to buy?
andymctractor
Post by andymctractor » Wed Mar 21, 2018 9:06 am
Hi, many moons ago I bought a pair of those rail cutting side cutters for OO and OO9 track. The positive thing about them for me was that the cutting surface was on the very edge of the jaws. I didn't heed the instructions and I used them for cutting other than OO rail which resulted in the cutting edge looking more like a bread knife with notches etc. What I'm looking for is a bit more robust. A set of cutters that will cut a hard wire, pin or even a brass ba bolt or similar but preferably with the cutting surface on the edge of the jaws. I know I could use a small hacksaw and follow up with a file but I'm after the easy life. :shock:
Any ideas?
Andy McMahon
Re: Side cutters - which to buy?
Post by Lonsdaler » Wed Mar 21, 2018 10:16 am
I'm not sure there is anything 'beefier' than Zuron track cutters other than proper wire cutters, which of course, don't have the cutting blade on the edge of the jaw.
The best alternative I have found is mini cutting discs for Dremel type tools.
Jbs
Post by Jbs » Wed Mar 21, 2018 10:45 am
Zuron also make a set of cutters for hardened wire, including piano wire. I have a set and after seeing them in use, my wife asked me to buy her a set for some of the hard wire used in her jewellery making. I think I bought mine at a show from Squires or a similar stall, although I have seen them available since for mail order.
John
John Smith
Harrogate
markoteal
Post by markoteal » Wed Mar 21, 2018 10:06 pm
I'm a Dremel mini disk man (with some careful tidying up with a file)
Post by tom_tom_go » Wed Mar 21, 2018 10:24 pm
When I want to cut bolts I use a metal hacksaw. I tightened a nut up to just before the place where I am going to cut and once I have made the cut I unscrew the nut and it threads the bolt clean again.
markoteal
Post by markoteal » Thu Mar 22, 2018 7:55 pm
Good tip Tom - I like that one
andymctractor
Post by andymctractor » Sat Mar 24, 2018 5:35 pm
Hi all,
thanks for the list of ideas. I think I will be using the mini disc cutter followed up with a file. :D
Andy McMahon
