Hi guys,
Looking into starting a model of Welsh Pony. I've decided to base it on the Peter Angus England using an SVS motor.
Are there anyone on this forum that is lucky enough to own one of Peters Englands? Would like a few pictures of the underside and where the boiler sits if possible?
Thanks
Peter Angus George England
Re: Peter Angus George England
If you are going to follow Peter's loco building process, do you have a copy of his book? It is still in print at Camden and worth it as a tutorial in thinking outside the box.JMORG wrote: ↑Wed Dec 27, 2017 6:14 pm Hi guys,
Thanks
https://www.camdenmin.co.uk/collections ... ve-builder
The Englands are described in the Festiniog chapter, with a couple of photos of a chassis under construction and a short description of the boiler design constraints. Note that they are built to 17mm scale to squeeze everything in.......
Cheers Graeme, I do have this book but unfortunately the pictures are quite small.
They may be the only game in town though.........
I usually scan any illustrations I find during the planning process of a new loco, so I can blow them up on screen. When I was building the Bagnall 2-6-2 all I could find was a couple of postcard size illustrations in books, so I scanned them at 1200dpi and put them on screen to look at.
If you have, or can access, a good scanner with a halftone scanning mode, you can pull a fair bit of info out of a small printed image once you can magnify and/or enhance it in a graphics program.
