Flanged bearings
Flanged bearings
I am looking for the type IP Engineering use for 3mm axles (1/8").
They do not sell them separately, I have asked in the past.
Thanks,
Tom
Thanks,
Tom
- -steves-
Re: Flanged bearings
Do you have a picture of the sort of thing you are after? And do you have the dimensions?tom_tom_go:123162 wrote:I am looking for the type IP Engineering use for 3mm axles (1/8").
Thanks,
Tom
I ask as I might be able to knock some up on the lathe for you if they are simple and quick to do? How many are you after, depends on that as I don't want to be there all day doing it, lol
Steve
Houston Gate Locomotive Works (HGLW) do flanged oilite bearings. Bronze bearings, flanged, £2.00 set of four. As pictured and listed on their website under Accessories. I have Used these since before David the current owner took over the company from Michael (Busted Bricks).Big Jim:123166 wrote:Try Roundhouse or Essel engineering.
Cheers
Roy H
Roy H
I think these are what I am after:
http://www.nairnshire-modelling-supplie ... -1601.html
They have the same dimensions as the IP one's I have.
- -steves-
To be fair, as much as I would happily make these for you, I could not even begin to make them any where near this efficiently. For the sake of £2.80, its just worth buying a pack of 12 from them as it would take me a couple of hours to knock these up.tom_tom_go:123177 wrote:I think these are what I am after:
