Locomotive sound - marine tugboat
sandy1000
Looking for an effective and inexpensive sound system for my locos, particularly the incoming Bulldog I came across this system meant for a small marine diesel. It sounds spot on to me.
http://www.mtroniks.net/resources/SmallDieselTug.MP3
There is probably a marine peculiar give- away about it and dimensions may be an issue - 40mm x 35mm x 15mm + 75mm speaker.
But it sounds right.
sandy1000
Another marine model sound unit
Following on from my previous topic I found another small diesel that may be used with Bulldogs and their type.
The site is at Harbour Models.
http://www.harbormodels.com/sounds.html
Try:
Small Diesel (HAR602)
You may find the fog horn a little inappropriate but the bell is superb.
But again the dimensions are probably too large. Perhaps the bulky items can fit into a trailing wagon with a small speaker up with the loco.
Try:
- sstjc
Don't know what the cost of shipping would be like or if these would fit your application but i've used these before but in bigger machines....
http://www.traxcontrols.com/modules.htm
Barry
Barry
DLRdan
I've got one of the sound cards from Acme engineering for my small diesels.
http://www.acmesteam.wiserhosting.com/sounds.html
Locoworks use the unit you describe in their Bulldog conversion:
You do not need to use the massive speaker that comes with it, you can you smaller speakers that are fitted in OO gauge sound locos.
What are R/C set up will you use as to turn the unit on/off remotely you may need a micro switcher:
http://www.mtroniks.net/prod/RC-Accesso ... itcher.htm
I will try and do a thread today on the Brandbright Cricket I have converted to Deltang with the Mtroniks sound chip with a video so you can see how it all works but for now here is our Rik with an example:
https://youtu.be/DjMJ26r--BI
- Palmerston
with ACME sound and instructions where to fit the card
[video]https://www.youtube.com/watch?v=pAxSeRIleIw&t=137s[/video]
Do fit the volume adjuster accesable from outside IF possible. Saves you dismanteling the loco.
Am currently converting an LGB loco with Deltang and Mtroniks but will be completed in about 6 months as i need the Massoth uncouplers which are waiting for production due to a retooling at the manufacturer.
Sadly Roundhouse locos do need to be preorderd and can take a year to be produced.
Live steam on 45 & 184mm, battery 45mm only.
Re: Locomotive sound - marine tugboat
The MTroniks unit sounds OK in a medium sized NG diesel loco.sandy1000:123098 wrote:Looking for an effective and inexpensive sound system for my locos, particularly the incoming Bulldog I came across this system meant for a small marine diesel. It sounds spot on to me.
http://www.youtube.com/watch?v=LfKq9esr0Jw
With Deltang, you don't need a switcher unit as it can be triggered by the 0v outputs from a receiver such as the Rx65 (I use output pad 9 or 10 which give 0v when the direction switch on the Tx is operated)
https://riksrailway.blogspot.co.uk/2015 ... rx65b.html
