Does anyone else hate it when this happens?
James from Devon
Post by James from Devon » Sun Feb 19, 2017 5:58 pm
You have a good running day, 4 or 5 trains out and about with a nice variety of rolling stock.
Then you pack everything away and at the last second, you notice this:
I'll be getting everything out again this evening and looking for the missing nut / bolt!
Post by Big Jim » Sun Feb 19, 2017 6:14 pm
Well it's clean so probably not off a steam loco.
Looks like a nut for securing a buffer.
There is an old trick in the motor trade that used to get played a lot.
When someone had a gearbox or engine stripped and laid out neatly on a bench some rotter would add a couple of odd fastings or parts to the arrangement when the chap doing the job wasn't looking.
Watching someone stand there with a really confused look on their face with parts left over and no place to put them was priceless.
You could play a similar trick at a steam up by strategically leaving odd bits about. If you were feeling evil that is.
James from Devon
Post by James from Devon » Sun Feb 19, 2017 6:21 pm
Big Jim:122929 wrote:Well it's clean so probably not off a steam loco.
Yeah, more than likely some incidental fitting that's about to drop off a wagon but as a lover or practical jokes....I thank you for a giggle and further inspiration! :)
markoteal
Post by markoteal » Sun Feb 19, 2017 6:30 pm
And the location of where it has dropped adds weight to the suggestions its a coupling nut.
No doubt at your next running session, you'll find out which wagon or coach its from when the loco pulls off with just the coupler attached!
Post by LNR » Sun Feb 19, 2017 10:58 pm
Yes James, been there and done that. Hope the detective work solves the case.
James from Devon
Post by James from Devon » Mon Feb 20, 2017 5:12 pm
Happy to report that the nut came from a battery box mounting bracket from one of my new carriages! Now back in its rightful place accompanied by a blob of loctite :)
markoteal
Post by markoteal » Mon Feb 20, 2017 8:18 pm
Good old Loctite! 8)
Killian Keane
Post by Killian Keane » Sat Feb 25, 2017 4:30 pm
To avoid loosing nuts and bolts entirely, why not make a wagon fitted up with magnets, so as to collect up ferrous metal fixings? ;)
James from Devon
Post by James from Devon » Mon Feb 27, 2017 11:57 pm
Killian Keane:123086 wrote:To avoid loosing nuts and bolts entirely, why not make a wagon fitted up with magnets, so as to collect up ferrous metal fixings?  ;)
That's a genius idea! :)
Killian Keane
Post by Killian Keane » Tue Feb 28, 2017 2:32 am
;) thanks James! Of coures, it also means you'll be picking up nuts and bolts from other peoples rolling stock also, but better than fixings getting lost altogether!
Post by MDLR » Fri Mar 03, 2017 9:58 pm
If you have a canal boat, you will know of something called a Sea Searcher Magnet which will pick up VERY heavy weights. Mind you, you'll need a well wagon to carry it........... https://marinestore.co.uk/Sea_Searcher_ ... agnet.html
Brian L Dominic
Managing Director
Flagg Fluorspar Co
www.mdlr.co.uk/ff.html
