Post
by jim@NAL » Fri Jan 20, 2017 7:41 pm
jim@NAL on Wed Feb 22, 2017 4:20 pm, edited 1 time in total.
sstjc
Post
by sstjc » Fri Jan 20, 2017 8:36 pm
I like that a lot. I don't recognise the power unit though...
Barry
Post
by jim@NAL » Fri Jan 20, 2017 8:49 pm
it is was an LGB stainz
sstjc
Post
by sstjc » Fri Jan 20, 2017 8:51 pm
Aha... so you are on 45mm... I've stayed on the darkside with 32mm. Its a very nice build though.
Barry
Post
by jim@NAL » Fri Jan 20, 2017 10:48 pm
Post
by LNR » Fri Jan 20, 2017 11:10 pm
"What not built of timber, Jim", only joking!
looking good, interesting build, plenty of weathering scope there.
Post
by jim@NAL » Fri Jan 20, 2017 11:32 pm
its having some timber on it ...the floor inside and the front end is going to have some wood on it .planning on heavily weathering the locomotive
Post
by Peter Butler » Fri Jan 20, 2017 11:45 pm
Nice work Jim.... looks like a make-it-up-as-you-go kind of job, just the way I work! You make it look as though you are comfortable with plastic card too.
Post
by jim@NAL » Sat Jan 21, 2017 12:16 am
getting a lot lot better with plasticard now its fun stuff to work with and reasonably cheap too so doesn't matter to much if you make a mistake the right glue helps (I use ema plastic weld I think) .it is very much make it up /google a few pics look in a few books for idea's etc
Post
by bazzer42 » Sat Jan 21, 2017 11:36 am
Liking it Jim.
I'm enjoying my 7/8th adventure as you have to build everything. I think I'm a builder more than a runner but everything starts to look right on 45mm track.
I have to agree that there is something about a tatty small scale operation.
Post
by jim@NAL » Sat Jan 21, 2017 4:18 pm
its a good fun scale to work with and like you say you have to build everything.im starting off with this locomotive and if this goes to plan I will change my line to 7/8ths .this will mean changing everything on my railway a few of the buildings could be modified or changed .the only down side is finding decent vehicle's but if found a company called kamteck that make rc car body's that people use for rc banger racing.these are manly old cars and would just need spraying and a set of wheels added .
Post
by bazzer42 » Sat Jan 21, 2017 7:31 pm
PS Jim if you need rivets I use nail art decorations. They are dirt cheap on ebay and stick well with solvent.
Post
by jim@NAL » Sat Jan 21, 2017 9:25 pm
thanks for the tip that's a very good idea
Post
by jim@NAL » Sun Jan 22, 2017 8:47 pm
Post
by jim@NAL » Sun Jan 29, 2017 6:58 pm
Post
by tom_tom_go » Sun Jan 29, 2017 8:39 pm
Looks good, well done.
Just shows plastic can be abused to look like banged up metal.
tom_tom_go on Mon Jan 30, 2017 8:28 am, edited 1 time in total.
Post
by LNR » Sun Jan 29, 2017 10:26 pm
Certainly looks well used, and typical of the state many would be in. Did you make patterns, do you intend making some more to build up a train?
Post
by jim@NAL » Mon Jan 30, 2017 5:39 pm
iv precut a lot of the bits when I made this one and am going too make two more this size with the same used affect
Post
by bazzer42 » Mon Jan 30, 2017 6:29 pm
That tipper body looks nice. I thought plasticard would be too tricky and spent precious money on some lgb spares
I should have given it a go.
Post
by jim@NAL » Mon Jan 30, 2017 10:56 pm
get some plasticard and have a go that's what iv done .
started painting the loco tonight
