16mm signals
16mm signals
Whilst searching 16mm accessories the other day, I came across some nice plastic semaphore signals but having tried all the websites and Google, I can't seem to find them again.
They where and all plastic kit, including the signal post aswel, and if I remember right, very reasonably priced at something like £8.
Has anyone come across a similar signal to what I'm describing?[/url]
- -steves-
- -steves-
Or if you want them made for you and you have a bit of spare cash to spend?
http://www.users.waitrose.com/~chazharr ... 20spec.htm
- -steves-
- -steves-
more options
http://www.carnforthmodels.co.uk/page4.htm
Gauge 1 but I am sure could be modified http://www.tenmille.com/Trackside.html
- Chris Cairns
At £8 it will be the Modeltown ones? - http://www.modeltown.go-ecommerce.com/s ... 17-1274003
Signals on ebay: http://www.ebay.co.uk/sch/spara01/m.html
- andymctractor
I bought a number of signal kits from Pendle Valley during the recent show at Peterborough. These are the ones given as an option by -steves- listed under carnforthmodels.
I appreciate they are £23 and a lot more expensive than your target price and I haven't built mine yet but they look very good and likely to be robust in use. (I appreciate that I'm recommending them by peering into my 'to do' box. )
I started with a plan for signalling that was far too ambitious. When I factored in the price of the kits I was forced to reduce signalling to something like a minimum set up. As narrow gauge lines usually tend/tended to have minimal signalling, if any at all, I was forced into a more realistic albeit freelance approach.
Good luck
Good luck
Andy McMahon
Andy McMahon
- -steves-
Good find, thats probably the onesChris Cairns:118432 wrote:At £8 it will be the Modeltown ones? - http://www.modeltown.go-ecommerce.com/s ... 17-1274003
Spot on Chris thanks-steves-:118435 wrote:Good find, thats probably the onesChris Cairns:118432 wrote:At £8 it will be the Modeltown ones? - http://www.modeltown.go-ecommerce.com/s ... 17-1274003
These are Modeltown signals with added lamps and ladders. For the initial price and the cost of the lamps, ladders and bits of Plastruct, etc I think that they make very acceptable signals at an economic price. This is two of four currently in service, with a least another four to be built. The power for the LED in the lamp is via self adhesive copper tape on the back of the post, with thin wire between the top of the post and the LED, and again from the base, through a hole to a terminal block under the baseboard. To stop them falling over a plastic dowel is inserted into a hole drilled into the base of the signal, which then slots into a hole in the baseboard; so two holes per signal, one for the dowel and a smaller one for the wires.
Don't know what's wrong with the first signal, but he's been up that ladder for a week!
Merlin
- IrishPeter
My general approach on for narrow gauge would be home signals on the approach to passing loops, and junctions, and not a lot else. The Light Railways Act of 1896 required only pretty minimal signalling - homes at loops, etc; distants only when the sighting was bad for the homes - though in practice there was a certain amount of negotiation between the BOT and the Light Railway as to what was acceptable. The C&MR had homes and starters, but managed to get a 20 mph speed limit out of the BOT, then on the other hand, the WHR was not required to proved fixed signals at all, and even had unmanned (strictly speaking TMO) crossing loops.
Peter in AZ
Peter in AZ
