PLine 16mm brass freelance tractor loco
pline
Post by pline »
Hello All,
we have introduced a brass made freelance tractor loco in 16mm for those who want to get started in 16mm.
The model has a brass body shell and chassis, with cast brass smoke stack, axle boxes, hand rails, brake column & wheel. Etched brass details & name plates. Directional LED headlamp, Mosfet based PWM speed controller, with speed adjustments made by turning the brake wheel. Direction/stop switch inside cab. Aluminum buffer beams and multi height buffer couplers. Window glazings supplied along with model. Powered by a 6v motor, powering a metal worm and belt drive
Model to be available as unpainted brass.
Price: GBP235 each (inclusive of delivery by DHL to anywhere in the U.K)
We accept payments through PayPal
Paul Nilanjan
E-mail: info@pline.co.in
