PLine DHR NDM6 body and complete brass kits in 16mm
pline
Post by pline » Mon May 23, 2016 1:15 pm
Hello All,
Our first complete brass kit products were launched earlier in the month.
The first in line is a kit for the DHR NDM6 in 16mm.
All brass parts are supplied with the kit to build the body shell. Most parts are factory formed, cast, machined, all holes drilled and threads tapped. Contains all necessary photo-etches for the body work.
Builder needs to solder them together using a soft soldering torch.
Some small hand tools, paints, decals etc are required to complete the model.
The kit is available as a complete body kit or as a complete kit with our unpainted RTR NDM6 brass chassis in the same scale. With all metal drive trains powered by two 12v dc motors.
CD containing detailed assembly instructions and 16mm scale CAD drawing included with kits.
Details available on our website http://pline.co.in
Prices:
1.complete kit including RTR chassis, buffer plates & DHR couplers:GBP370 each
2.complete body shell only:GBP300 each
3.RTR chassis, buffer plates and couplers: GBP250 per set
Note: above prices are inclusive of delivery charges by DHL to anywhere in Europe.
Photos and parts list attached.
Paul Nilanjan
Click to download file
