NWNGR Moel Tryfan
NWNGR Moel Tryfan
Decided to split this from another thread regarding the Morgan works.
The locomotive has has a design modification: The outside cylinders have been replaced by a hidden SVS motor with gear drive to the power bogie.
Dad modified the frame to accept the motor and has started the sheet work. I've modified a Billy smokebox (with new chimney) to better resemble the prototype more closely. The bogie pivots are now in place.
The locomotive will be painted and detailed as it was at the turn of the century (before it's merger with Snowdon Ranger).
[/img][/b][/quote]
[/img][/b][/quote]
An update:
Bodywork pretty much complete except for a few small things (thanks to dad for that). I've started on the various detailing components, such as the sandboxes and the large air brake receiver (to go on the RH side).
Dad has soldered the smokebox and fitted the handrail and lamp plug. I've been attaching the Brandbight couplers and completing the buffer beams.
The locomotive now only needs plumbing to run!
As you can see the cylinders and bogie details are still to do. Hopefully we'll be able to find Peter Angus at the show and ask how he did his for his various Fairlie locomotives...
By the way, the locomotive lurking in the back is a part built Mayumbe Garratt. Dad is currently building two of these beasties! Hope to do an update on those later in the year once the house extension is complete.
Moel Tryfan has progressed rapidly in the last few months and is now running regularly and very well; pulling decent trains whilst running in.
Temporary coupling rods were made so that the engine could run. These pictures were taken a few weeks ago during its first run with carriages. It has pulled 6 bogie carriages with no effort although I tend to run it with 4 during running sessions to enable it to keep up with other engines.
As of now:
The locomotive now sports fresh laser cut rods (Stainless) and has had the Salter safety valve finished. It now only needs small details to finish (mainly to the chassis).
The locomotive is to have a new roof as the current one was damaged. This will be for the original "open" version. The distinctive, fully enclosed version will be remade once the engine is finished (the cab back is fixed to the roof).
I have sent these pictures to my original workshop instructor at Gloucester Engineering Training. He has asked for my permission to exhibit the locomotive for the college's open days (the first being January) to encourage Apprenticeships in Mechanical Engineering. Hopefully my company may also do the same!
As of now:
- New User
Hi James,
Thanks for the compliments!
The motor drives the front bogie as per the norm. Most of the weight is on the front so it provides good traction that way.
Dad has built a Meyer in the past using various left overs including a modified Russell body! This one was built with the motor in the middle, powering both bogies via cardan shafts.
Click here to see:
https://m.youtube.com/watch?v=Xcm3TgXZYY8
Click here to see:
Finally finished! Moel Tryfan stands at Jason Junction; resplendent in it's new livery by Barley Pit Works.
Although it's run in the brass (and run well), I haven't yet run it fully painted; partly because of the weather but more importantly because of the fact it's my Apprenticeship project.
Last Wednesday the locomotive was displayed at the company open evening as part of the "Apprenticeship" stand; being looked after by one of the department managers. Apparently many visitors loved the model including the Chairman himself! He tried to organize a chat with me the next day via the apprenticeship management although I had to decline due to the full day of meetings I had with customers...
Still, apparently he wants to meet me in the new year, best get my suit out...
Moel Tryfan will be next displayed at the Gloucestershire Engineering Training open evening in January as part of my companies' stand. I promise to run it after that!
- Dannypenguin
Looking good Jason! Look forward to seeing her running soon(ish)...
Dan
- paullad1984
Re: NWNGR Moel Tryfan
Because Sunday was a nice day, and because I finished the Gladstone carriage:
https://m.youtube.com/watch?v=-HGH2IaG0fE
The red VoR carriage is posing as a summer carriage until the real one is done.
She certainly does run well and looks beautiful too!
A proud moment for you I'm sure.
Finally! It had a burner issue, not wanting to burn very well and no amount of gas would help! We eventually found that the burner was covered in a soot-like(!) substance, most likely from a bad gas can.
Swapping the burners made it run! Still needs plenty of running in order for it to run as well as our Peter Angus Fairlie. In the brass we had it running with 6 bogie carriages and 3 4 wheelers, pulled this with ease!
Looks great and with a performance to match. Congrats to you, and your Dad
Merlin
