Tubs
- listerboy
Tubs
Hi
I'm considering making a rake of tubs similar to this ;
http://www.swiftsixteen.co.uk/index.php ... uct_id=316
I'm curious, how would the contents have been removed on the real railway?
- andymctractor
Perhaps they are propelled one at a time onto end tipping apparatus or are picked up side on similar to loco coal wagons on some larger standard gauge loco coal towers.
The truth is I don't know but they do look good especially when well weathered.
Andy McMahon
Andy McMahon
On a Wagon Tippler* - a rotating machine that turns the whole bally tub upside down so that the contents are Gravity Assisted to their next destination.
On a sophisticated set-up, the couplers are on ball-joints so that the train doesn't need to uncouple - merely step forward one wagon at a time. But on simple tubs (such as British Railways with their side-buffers) it's still quite labour intensive, albeit less so than Shovelling.
David
If googling, be sure to put Wagon in or you'll just get a load of pigeon erotica.
David
Re: Tubs
Depended on the mining tramway in question. Some small ones did it the hard way by tipping them with a long pole and a couple of hefty miners. Most were more sophisticated and used tipplers, either side unloading, or end unloading. Side unloading was quicker.listerboy:116164 wrote: I'm curious, how would the contents have been removed on the real railway?
Small underground mines would be unlikely to have bothered with special couplings, but big open cut operations like Aust. iron ore and coal mines use tipplers and rotating couplers on the cars to unload trains without any uncoupling or shunting. Takes a couple of hours to unload a 30,000t train from memory. There are videos on YouTube.
You'll find a scan of a Hudson's catalogue here on the cane-sig website
http://www.zelmeroz.com/album_rail/uk/m ... als-gs.pdf
Along with a lot of other items eminently worth modelling, on page 98 you'll find illustrations of both type of tippler supplied by Hudson, the sort that would have been used by small ng mining operations.
I've seen working ones in HO, so it should be possible to build one in garden scale.........
I think the stay serves a dual purpose. The first is to stop the tipper from going over while on the move, the second is to stop the chassis falling during tipping by anchoring it to the rail not the ground.
There are some tubs shown in this video, it also shows how they are emptied.
https://www.youtube.com/watch?v=unhXEQQk8G8
Dan,
DLR
www.freewebs.com/dlrail
DLR
- andymctractor
Found this.tuppenced:116167 wrote:On a Wagon Tippler* - a rotating machine that turns the whole bally tub upside down so that the contents are Gravity Assisted to their next destination.
https://www.google.co.uk/imgres?imgurl= ... MwhKKBswGw
Andy McMahon
Andy McMahon
Lister, Brass is a pretty poor bearing material. People only get away with it for models because the loads are small and the duty cycle consists mostly of standing on a shelf. Which are conditions that plastic bearings are quite happy with.listerboy:116208 wrote: I'm used to brass and metal!
Unless the loads are sufficient to squish the plastic, or the temperature high enough to soften it, there are many plastics that outperform brass, notably (in no particular order) PTFE, Delrin etc, Tufnol/Paxolin, and the Nylon used by the Binnie dynasty.
Plastic cable clips make excellent inside bearings. For example Binnie 3mm axles clip in and out of a 3.5mm clip without taking the wheels off. (Fix the clip n way round not u way.) They are available in brown and black as well as white e.g. from Maplins.
If there's a good reason for a metal bearing, then Phosphor Bronze rod is the way to go for home made ones, or 'Oilite' self-lubricated sintered bronze which can be had Plain or Flanged.
David
If you prefer to install the clip Open side upwards like a letter u, it will rub on the frame unless you add a bit of bearing plastic between the clip and the frame. Also, the wheelsets will be trapped.
So I'm suggesting Open side downwards, like a letter n, which means you can clip the wheelset in and out without undoing screws. This works because the profile has two 'nibs' that retain the axle.
The picture is of the underside of an underframe:
and you can see one of the nibs if you peer hard enough.
Either way up, the axle will have a small vertical play which, on an inside-framed wheelset, gives a handy bit of Compensation.
For spoked wheels, where the outline is vaguely visible, one can get a slightly more Scale appearance - or at least, a more plausibly symmetrical appearance - by slicing two clips at the top of the arches, and fixing half of each face to face.
David
David
