Hi,
Does anybody know what the maximum stroke that a RH cylinder can do?[/b]
Max cylinder stroke for Roundhouse cylinders
- JMORG
- GTB
Re: Max cylinder stroke for Roundhouse cylinders
RH quote the stroke as 5/8", near enough 16mm in the new money.JMORG:114228 wrote: Does anybody know what the maximum stroke that a RH cylinder can do?
At 16mm stroke the end clearance is 1.5mm. You might get away with reducing the clearance to 1mm, which would increase the stroke to 17mm max.
You'd need to check that the piston o-ring doesn't overrun the port if the stroke is increased and you also need to be more accurate about mounting the cylinders.
What stroke were you hoping for?
