loco servicing cradle
Post by Big Jim » Sun Nov 08, 2015 4:14 pm
I currently use a shoe box with foam padding as a cradle to hold my engines upside down. It works but I am not overly happy with it.
What do others use or recommend?
Bill/Rubery
Post by Bill/Rubery » Wed Nov 11, 2015 9:59 pm
To tell you the truth I just turn my engines upside down on a large rag on my lap! Its worked for pushing 30 years!.......
Post by Andrew » Thu Nov 12, 2015 1:34 pm
You've got me wondering whether I should turn my engines upside down more often!
When I do my approach tends to be similar to Bill's, but I rather like the shoebox and foam padding idea...
Itareus
Cradle
Post by Itareus » Sun Nov 15, 2015 7:34 pm
Dive into the scrap box for some mdf or whatever you have for the base and sides and also find some 1x1 or 2x2 off-cuts for supports.
Screw/glue/nail or otherwise fasten together.
Glue foam or similar over the sides and bottom (pin or clamp until dry).
Not fancy but effective and also handy for keeping things right side
up while working on them.
http://itareustrainz.weebly.com/uploads ... 7_orig.jpg
Chris
Post by Peter Butler » Sun Nov 15, 2015 7:59 pm
I do like the foam-lined cradle idea although you might need two, one for locos only (to keep oil etc. off everything else).
I see another project in the pipeline.
Itareus
Post by Itareus » Mon Nov 16, 2015 12:00 am
To keep the cradle clean how about using cling film (or similar) when working on 'dirty jobs'.
Post by Peter Butler » Mon Nov 16, 2015 11:11 am
Is it my imagination (it can be quite active at times!) or do I recall seeing, on this Forum, a purpose built cradle which operates something like putting a loco between two rotating clamps, one at either end like a lathe?
If not, then I claim all royalties!!!!!
It would be a complicated thing to make initially, especially being able to cope with such a variety of lengths and buffer types, but once mastered it could solve all issues surrounding access. If it was your invention, please let us have details......
