Building Ruston in 7/8
St.Michael
Post by St.Michael » Sun Sep 27, 2015 3:33 pm
Hi all.
I have been fortunate to get me an Ipe-Ruston on sale. Almost ready but I would like to ask you about the little "pedal". Is it a clutchpedal, or something completely different? Where shall I put it?
Sorry about bad quality pics...
Thankful for help...
Michael
FBGR
Post by FBGR » Sun Sep 27, 2015 8:35 pm
There is no clutch peddle on a Ruston, the wet plate clutches (one for each gear) being engaged through the lever operated by the Right hand/arm when sitting on the seat.
The other levers are, the brake lever operated by the left hand, the one with the ratchet catches, and the forward/neutral/reverse lever which is against the bulkhead.
There are also two other small levers attached to the bulkhead, one for the throttle and one operating a paddle in the sand box.
The mystery part may be part of the brake rigging, although looks too big to be the bottom of the brake lever where it attaches to the shaft that runs to the other end of the loco.
JOhn de Havilland
St.Michael
Post by St.Michael » Mon Sep 28, 2015 12:54 pm
Hi FBGR (John?)
Thank you for a very enlightening answer. I think I will put the little thing on the chassis where the breaks shall be placed. :idea:
Regards from Michael
