Details of the build here: http://www.jasonplant.com/Pages/Railway ... ation.aspx
The method I'd used for the walls were to coat wood with glass resin and car filler to waterproof it. Well after a few winters the moisture still gets in no matter how well sealed you think it is, first the walls started to "bulge" as you can just see in this first photo and eventually disintegrate completely as in the next photo!
So this summer I've stripped the base off and started afresh but this time using Perspex as the base, I still used some car filler on the outside to add some texture and allow me to dremel out the bricks a bit easier.
The end result is pretty much back where we started and with a bit of weathering on the paint work it looks as good as .... well as well used station :-)
