My Andel models Ffion
Joe
Post by Joe » Sun Dec 21, 2014 6:59 pm
Post by bazzer42 » Sun Dec 21, 2014 9:09 pm
That's a nice industrial looking diesel and bigger than I imagined the andel diesels to be. I have some nice metal diesels, cricket, danny and criccith but I think I need to work on them to make them look more purposeful.
steamie1
Post by steamie1 » Sun Dec 21, 2014 11:40 pm
NicE! I like the outside rods.
Joe
Post by Joe » Mon Dec 22, 2014 7:52 am
Yeah the ffion is a bit bigger than the usual Andel models diesels, it has speed control and a plug to plug in charger to the mains which is handy although after about 4 hours of use it didn't show signs of dieing on me .
Post by Chris Cairns » Mon Dec 22, 2014 9:16 am
A nice collection of industrial rolling stock.
How do you get on running the slate wagons empty?
I've got a couple of the Cooper-Craft Ffestiniog Slate Wagons which I'm filling with painted cardboard slate loads but I've found the supplied weights are not heavy enough to keep them on the track when running with live steam so I will be putting some lead sheet underneath the slate loads.
Joe
Post by Joe » Mon Dec 22, 2014 10:11 am
Chris Cairns:106583 wrote:A nice collection of industrial rolling stock.
Hi, i dont actually own the slate wagons as the photo is from a visit to the Barley pit railway but having seen them being pulled by a ragleth they seemed to be fine, have you got tight radius curves? as the tension might pull them of
Post by Chris Cairns » Mon Dec 22, 2014 10:55 am
I actually had the problem with my Ragleth at the Llanfair show. The problem was the different types & heights of the various couplings used (not helped by the chopper coupling on the Ragleth) plus the weight distribution throughout the rake. The slate wagon was near the front but was getting shunted from behind by a heavier slab wagon (although the piece of ballast being used as a slab was chained down it was still free to move a bit - it is now glued in place).
I need to have a translator wagon where one of the pin/hook couplings is at the universal height of 24mm for a centre buffer coupling & chain.
sstjc
Post by sstjc » Mon Dec 22, 2014 11:13 am
With my tippers I used fishing weights, the little round ones which I brought in a tin at a boot fair, and when I had the right amount I set them in epoxy and put a more realistic load on top.
Barry
Barry
www.5inchrail.com
Post by Chris Cairns » Mon Dec 22, 2014 12:17 pm
With my Binnie skips I've also epoxied fish weights into the bottom of the shunting main beam (http://reviews.laurell.nu/kits/binnie-01.html), and I fill the skip buckets with a removeable sand load set with a PVA/water mix & kitchen film (takes over a week to fully set!).
I find the Cooper-Craft kits are just too light as built. I filled my LNWR coal wagon with genuine steam coal PVA'd in situ, but it is a little harder to hide extra weights on the slate wagon (chassis box already filled with the supplied weights). Hence my idea of placing a strip of lead inside the bottom of the cardboard slate loads, using what I have available rather than buying in resin/slate loads.
Enginehouse
Post by Enginehouse » Mon Dec 22, 2014 7:26 pm
I have not only used lead (flashing strip cut to size) under the chassis and thrown out the ballast boxes, but also fitted metal wheels. I thought that the supplied wheel mouldings spoilt a nice little kit.
With regard to couplings, I have my relatively tiny home made magnetic couplings fitted, which allow auto coupling and these being on a semi rigid swivel loop ensure no problem to haul or shunt with the occasional odd level couplings of some stock. Over run with a heavy slate slab running for example between empty slate wagons is almost negated by the semi rigid couplings so no bang together and jerk apart derail problem.
Post by Big Jim » Mon Dec 22, 2014 7:43 pm
A good source easy to hide weights are the self adhesive strips used by garages to balance alloy wheels.
The normally come in 6 inch strips divided into 5 and 10g blocks, the ones we use are only about 1/8'' thick and fit very well under a floor behind the sole bars.
