Ragleth Spectacles....
JimboJet
Post by JimboJet » Sat Jan 04, 2014 10:47 pm
Hello all.
I've just taken my brass spectacles out and reversed them around because I agree with Monsieur Gorton.
However I notice there is are some spots of super glue on the black external finish, which will not easily come off (i.e. with my fingernails!), and I'm not sure what to use to get it off.
Any ideas or help would be gratefully appreciated. I'm keen not to ruin my new engine.
Also I have some ACME spectacle glasses on the way. Do these need glueing in?
BWs, Jimbo
Post by Big Jim » Sat Jan 04, 2014 10:57 pm
I think you can still get Superglue remover or debonder. Failing that I have a feeling acetone will shift it. Or try a flat blade and a bit of pressure
Post by Big Jim » Sat Jan 04, 2014 10:59 pm
Just re-read your post....
Check on a hidden bit of paint first, acetone will lift some paints.
Post by laalratty » Sat Jan 04, 2014 11:08 pm
The spec glasses should just be a push fit, but you may find that they need either a bit of filing down, or a touch of superglue just to hold them
JimboJet
Post by JimboJet » Sun Jan 05, 2014 12:24 pm
Thanks for the advice....just found the superglue removal thread...typical!
I'll see how the spectacles go when they arrive laalratty. Cheers
Gremlin
Post by Gremlin » Sun Jan 05, 2014 2:50 pm
When I make spectacles they are slightly oversize and just run a file round the edges and keep offering them up. Mine are all a tight push fit, no need to glue.
Woodfields Light Railway
Post by Woodfields Light Railway » Sun Jan 05, 2014 3:41 pm
Should have gone to spec savers!!! :lol: Sorry........ Worst joke ever
JimboJet
Post by JimboJet » Sun Jan 05, 2014 4:05 pm
That's quite good. (Most apt as they are based on the island next door!)
At least you didn't make a spectacle of yourself WLR...
Thanks for that Gremlin
Post by Woodfields Light Railway » Sun Jan 05, 2014 7:10 pm
:shock:
