Im just in the process of rebuilding on of my battery loco's. Part of the rebuild will be converting form manual to RC, I want to use my exsisting Planet t5 transmitter and receiver with the ESC so it needs to work with a standard 2.4ghz receiver.
The motor is an MFA 540/1 4.5-15v and the stall current is 8.24A and the standard loaded running current is 2.85A. The power pack is made up of 10x AA cells.
I would like it to also be able to control the lighting with the direction of travel.
Dad has a Baguley diesel fitted with an Electronize ECU and Im not a big fan of it, I dont think its responsive enough or control.
What would the guys out there recommend?
Electronic Speed Control recommendation
- Steven.T
