On-board battery charging
Post by tom_tom_go » Fri Dec 16, 2011 1:08 pm
Hi,
On a live steam loco where the battery is only used to control servo's can I simply add an additional socket on the wires that link the battery to the receiver so that I may charge a battery pack?
Cheers!
Tom
Post by -steves- » Fri Dec 16, 2011 2:00 pm
You can, but you are better off with a charge lead switch harness which will only allow connection to charging when the switch is in the off position. I think this is what you mean?
http://www.ebay.co.uk/itm/FUTABA-STYLE- ... 58914577ae
Post by tom_tom_go » Sat Dec 17, 2011 6:27 pm
Thanks Steve that's exactly what I need although I found it cheaper here:
http://www.component-shop.co.uk/html/sw ... rness.html
Tom
