Edrig Banjo Bolts
anythingsdr
Edrig Banjo Bolts
Post by anythingsdr » Fri Sep 23, 2011 11:51 am
Hello there,
I'm looking into getting a Regner wistle kit for my edrig and using it off the banjo, can anyone tell me what the thread is for the Edrig's Banjo? Going to make a new Bolt and colar for it and maybe get a servo!
Charles M
Post by Charles M » Fri Sep 23, 2011 7:32 pm
I think the correct size is 5MM by .500 thread. I got my banjo bolts for my Edrig from David Bailey Engineering in the UK. I did the same thing you are planning to do. I used the Regner kit and made the new fittings to mount the whistle. I placed the lever for the whistle on the left of the throttle lever. ( On my engine , new lever ) The whistle is then placed between the tank and the boiler on the left side of the locomotive. The whistle blast is aimed down between the frames. This makes a very nice conversion , and it works very well at all pressures from 20 to 60 lbs . I have also fitted the same kit to my Accucraft " Earl " using the same parts and it works just as well.
Charles M :D
anythingsdr
Post by anythingsdr » Fri Sep 23, 2011 7:35 pm
Brilliant! I'm in the garden at the moment starting the DHR! In the dark! Between you and john @ trackshack. Today has been very productive!
