New AnDel Loco
Dr. Bond of the DVLR
New AnDel Loco
Post by Dr. Bond of the DVLR » Tue Nov 02, 2010 9:13 pm
Mr. Andy Bell's been busy by the looks of things with this powerful little beast on test:
http://www.youtube.com/watch?v=5HJYobhejrY
Its designed to be powerful enough to haul dead steamers and longer trains.
SLRmidge
Post by SLRmidge » Tue Nov 02, 2010 9:29 pm
Looks good. :D
Post by Narrow Minded » Tue Nov 02, 2010 10:11 pm
That did well didn't it - on wet rails too!
andelmodels
Post by andelmodels » Wed Nov 03, 2010 9:04 am
The loco was designed as a prototype to look into the feasibility of articulated diesels. The "design brief" is that the loco should be able to stand in for a steam loco with the max spec of the loco costing around the same price as a budget steamer.
Another version of the loco is to be built to look at manual options, battery discharge and the like. will keep you posted,,
Andy
Post by Narrow Minded » Wed Nov 03, 2010 9:10 am
Nice one Andy, it certainly looks like it's going to be a winner! :D
LMS-Jools
Post by LMS-Jools » Wed Nov 03, 2010 6:22 pm
Yes looks very nice. 8)
andelmodels
Post by andelmodels » Wed Nov 03, 2010 7:32 pm
Today the loco had a continued running endurance test. The loco ran for 2 hours before the loco needed recharging. Slightly less than I would have liked but I think acceptable.
I Will be building a green manual control one for development purposes, hopefully starting this evening. I will also be doing some more tests on the current loco. I will keep you posted on developments.
Andy
Pendo Pilot
Post by Pendo Pilot » Wed Nov 03, 2010 9:25 pm
Looks very nice indeed & seems to have good power. Did I see a bogie lift slightly during one drag though? or maybe it was just the camera angle. Was just wondering if it was the power making the bogie lift?
As for 2 hour running time, I have to agree that would seem acceptable. For comparison I get between 2 & 1/2 hours out of my Jessie with the best rechargables in at a steady pace. Will there be an in situ charge point on the loco. Just something I was thinking of trying out on mine. The idea being I could then have a charge lead wire next to a siding & have the loco stabled there charging the batteries until it is needed to rescue something. Rather than have to remove bodywork & batteries etc.
Is there a guestimate on price yet or is it too early to tell.
Sir haydn
Post by Sir haydn » Wed Nov 03, 2010 9:29 pm
Brilliant Andy as always. I rekon you should make a battery loco like the talyllyns Midlander. A really pretty little IC loco
Post by Narrow Minded » Wed Nov 03, 2010 10:42 pm
Sir haydn wrote:Brilliant Andy as always. I rekon you should make a battery loco like the talyllyns Midlander. A really pretty little IC loco
Seconded, especially as you already have the Merseysider - you wouldn't want to be accused of bias now, would you, eh, mmh, ?
andelmodels
Post by andelmodels » Thu Nov 04, 2010 6:50 pm
Hi, The loco has a built in charge point as I hate having to take things to pieces to get to the batteries.
In the past this has caused much amusement to the missis, counting the "bums" in the air as people try to find the small screw that holds the body of a loco on.
andelmodels
Post by andelmodels » Fri Nov 05, 2010 12:22 am
Hi All
The Back bogie climbed about half way through the video when it road over some track ballast due to the perpetual Nelson rain.
MTA
Post by MTA » Sun Mar 20, 2011 12:46 pm
Any news on this project, Andy?
I'm looking for a powerful diesel outline loco to rescue dead steamers, and yours is the most appealing.
DVT Dweller
Post by DVT Dweller » Sun Mar 20, 2011 3:36 pm
May I ask what you used for the bogies on it? Im building a bogie diesel at the moment and want it to move steam locos but dont know what to use as a power unit.
ptlrcecil
Post by ptlrcecil » Sun Mar 20, 2011 5:12 pm
If it will drag a steamer and train i want one.
