Weathering
taliesin001
Weathering
I'm thinkng of getting a couple of locos weathered but really don't want to touch them myself. Does anyone kow of any proffesionals that will offer this service?
- Dr. Bond of the DVLR
- Retired Director
Have a look at this video if you've not already seen it. Very inspiring.
http://isleofwestland.webs.com/weatheringmethods.htm
taliesin001
Sir haydn
taliesin001
Endless, Nameless
Well I never knew that! Just goes to show what you can pick up on hereIt is actually an Oho- they did several names, Otto just being the first and most common.
That sounds like an offer that you can't refuse! (And when you've "mastered" the technique - really go overboard and weather it to a "distressed" state and stick it at the side of the engine shed)
ianfolland
Your wagons are very good, so why not locos as well! As Sir haydn says study plenty of photographs. You'll also need to view the work as it progresses outside from time to time as what looks right indoors might not be the right colour outside. I finish my models ex-works then dry brush the weathering (I prefer that to airbrushing). I use a variety of enamel paints, and have recently started using "Scenic Rust" as well. My hoppers and skips have rust effects using this stuff:
My Garratt was weathered by dry brushing using photographs of 143 on the WHR found on the internet, and my class 45 (see ./myff/729608/19-colour.jpg ) and other 7mm stuff is done referring to photographs.
"The Art of Weathering" pub by Wild Swan is worth a read as well.
Having seen your wagons I'm sure we all look forward to seeing the results!
taliesin001
Thanks very much for the offer, but I do have quite a few bits and bobs to practice on and if I didn't end up doing it myself I would feel as though it had gone to waste, seeing as I can't do anything with it afterwards (no railway!Endless, Nameless wrote: I have an LGB porter cab and boiler which you are welcome to have for the cost of postage to practice on- not as good as a complete body though.
- TonyW
Mmmmm.... Proper livery. Proper number. Gorgeous!ianfolland wrote:... and my class 45 (see ./myff/729608/19-colour.jpg ) ...
ianfolland
Taliesin - I forgot to suggest delving into 7/8ths stuff on the internet as there is a lot of US influence and American weathering techniques seem to be far in advance of ours.
TonyW - "proper livery, proper number".....have you seen http://grahame910.fotopic.net/ ? My 7mm modelling is of locos and stock that could have been seen in the Birmingham area in 1970. The "7H14" headcode on the Peak was a Burton on Trent to Banbury freight at that time.
Ian.
Ian.
- TonyW
I have already spent several happy hours going through that site. Definitely my favourite era!ianfolland wrote:TonyW - "proper livery, proper number".....have you seen http://grahame910.fotopic.net/ ?
taliesin001
taliesin001
