tight 32mm curves
pauly
tight 32mm curves
Post by pauly » Fri Nov 13, 2009 9:17 pm
What is the tightest 32mm set curve available?
A steam propelled life-style.
andysleigh
Post by andysleigh » Fri Nov 13, 2009 9:29 pm
peco do a 30" radius set curves
pauly
Post by pauly » Fri Nov 13, 2009 9:33 pm
andysleigh wrote:peco do a 30" radius set curves
is it tighter than mamod curves?
whats the width of a full circle of Peco 30?
andysleigh
Post by andysleigh » Fri Nov 13, 2009 9:35 pm
duno what its like against mamod track
the diameter would be 60"..
2x30
made-in-england
Post by made-in-england » Fri Nov 13, 2009 9:41 pm
mamod curves are 1ft, so 12inches...
pauly
Post by pauly » Fri Nov 13, 2009 9:54 pm
OK
sorry lads but Im really confused here :scratch:
SillyBilly
Post by SillyBilly » Fri Nov 13, 2009 10:00 pm
The Faller curves that often come up on eBay are of a very tight radius.
Mamod track radius is 2ft 6in.
pauly
Post by pauly » Fri Nov 13, 2009 10:02 pm
Im only using stuff thats currently available
Ill hav eto find some of that Peco 30 stuff
didnt Pete use some on his extension? looks tight!
SillyBilly
Post by SillyBilly » Fri Nov 13, 2009 10:06 pm
http://cgi.ebay.co.uk/Faller-E-Train-0- ... 0365399442
Oval of Faller track, I wouldn't reccomend running meths locos on it thou.
mhlr
Post by mhlr » Fri Nov 13, 2009 10:10 pm
pauly wrote:didnt Pete use some on his extension?  looks tight!
Yes, quite tight and you wouldn't want to go any tighter, but most things will run on them.
Endless, Nameless
Post by Endless, Nameless » Fri Nov 13, 2009 10:55 pm
Faller stuff looks great for a properly light railway. I had a load that I should never have sold, sat really well with the Big Big Ruston I had at the same time. Might get away witha mamod/ Jane on it but anything bigger steamwise would look silly.
DLRdan
Post by DLRdan » Fri Nov 13, 2009 11:15 pm
peco set track is the same radius as mamod track and both have a 5 foot diamerter circle when made. All of my locos will happily go round my curves although i did have to move my Lawley's wheels in a bit further so it wouldn't bind so much
andysleigh
Post by andysleigh » Sat Nov 14, 2009 3:32 am
alternatively you could jsut buy a lenght of peco flexi track, and then u can bend it to how eve ru like, but it needs a proper bed to keep it in place
pauly
Post by pauly » Sun Nov 15, 2009 2:59 am
thanks for all the ideas guys, Im gonna go with mamod track though since I already have some and only need a couple more pieces for what I have in mind. :D
Dr. Bond of the DVLR
Post by Dr. Bond of the DVLR » Sun Nov 15, 2009 10:30 am
and what might that be?
