how I made my own cheap straight rail
Sam95
Post by Sam95 » Thu Apr 17, 2025 9:43 am
For my extension project and to reduce the cost I decided to search how to make my own straight rail. After few research I found a sleepers model compatible with LGB on thingiverse. You have to use cheap aluminium 10mm X 2mm profil to make the rail. It is perfect for me as my locos are battery powered. But it is not compatible with rail power.
https://www.thingiverse.com/thing:1584413
The sleepers once printed in PETG were a little bit to slim to perfecly fit with LGB rails; so I imported the STL in tinkercad and modified its thikness :
The modified STL is available on my blog.
I also cut a small notch thus the LGB splint can fit perfectlty :
The 2.4 meters long section of rail cost me about 30 euros (aluminium profile and PETG)
You can visit my blog
http://sam95.fr/
Re: how I made my own cheap straight rail
Post by philipy » Thu Apr 17, 2025 10:22 am
Very nicely done Sam. :salute:
Would you also consider putting the stl's in our forum 3D Print Files library, please? viewforum.php?f=55. Once your post has moved down the list of posts this link will disappear from being easily found.
GAP
Post by GAP » Thu Apr 17, 2025 11:06 am
If you are printing in PETG and using it outside then may be this might be of interest.
https://www.thingiverse.com/thing:810196/remixes
https://www.thingiverse.com/thing:976643
Sam95
Post by Sam95 » Fri Apr 18, 2025 8:46 am
philipy wrote: Thu Apr 17, 2025 10:22 am Very nicely done Sam. :salute:
File posted in the requested forum.
http://sam95.fr/
Post by philipy » Fri Apr 18, 2025 12:55 pm
Thanks :D
Post by Old Man Aaron » Sat Apr 19, 2025 4:05 pm
Good work, a huge saving. :thumbup:
Post by Lonsdaler » Fri Apr 25, 2025 9:14 am
Sam95 wrote: Thu Apr 17, 2025 9:43 am For my extension project and to reduce the cost I decided to search how to make my own straight rail. After few research I found a sleepers model compatible with LGB on thingiverse. You have to use cheap aluminium 10mm X 2mm profil to make the rail. It is perfect for me as my locos are battery powered. But it is not compatible with rail power.
That's very well done. Is the PETG UV stable? It would be a shame if it were to be damaged by sunlight.🤷‍♂️
Sam95
Post by Sam95 » Wed Apr 30, 2025 8:08 am
For the UV resistance, yes PETG should be ok.
http://sam95.fr/
Post by Lonsdaler » Thu May 01, 2025 9:11 pm
Sam95 wrote: Wed Apr 30, 2025 8:08 am For the UV resistance, yes PETG should be ok.
Excellent!
Palmerston
Post by Palmerston » Fri May 02, 2025 2:18 pm
I think its faster, cheap and more beautiful to buy a set of secondhand R1 LGB track and bend them straight. Often they show up 8 or 12 pieces of track for as little as 2 to 5 euros per piece. The sleepers are quick to detach from the rail and straighten the rail in your vice.
Live steam on 45 & 184mm, battery 45mm only.
Sam95
Post by Sam95 » Fri May 09, 2025 8:50 am
That is a solution that I never thought possible
http://sam95.fr/
