Thank you Boris for you Magnificent Factory window. Although I have printed it on my FlashForge, ("the arc at the top is centred at the bottom of the frame") with is the little dot does print out, but it's not attached to the file. Not a problem for me though, it is a brilliant file and printed really well. It took 28 minutes and used approximately 1.52 meters of filament.
It would be really easy to resize also for a smaller window if needed I suspect...
The start of the print.
- 1090B4B5-17DD-4F29-B8A9-E195E9457CF4.jpeg (2.31 MiB) Viewed 3733 times
- 7168E0F0-A5B5-42A3-A1D5-497E011C3C51.jpeg (2.29 MiB) Viewed 3733 times
And the end..
- B2D2919C-3447-4F3B-9510-077403B8A58B.jpeg (3.54 MiB) Viewed 3733 times
Has you can see it printed out great.
Thanks again Boris..
