Lighthouse
Lighthouse
Post by jim@NAL » Wed Jun 13, 2018 8:35 pm
Has anyone built a lighthouse for there railway I'm thinking of building one .my line is 7/8ths so it will be big .be good to see if anyone's made one and ideas for the light please
IanC
Re: Lighthouse
Post by IanC » Wed Jun 13, 2018 9:36 pm
Hello Jim,
I've not built a lighthouse. Two ideas come to my mind.
First copy the real thing. You're probably aware the light is fixed and a shield/reflector rotates around it. Something mounted on a set of bevel gears might suffice?
My other thought is there were some on that auction site. It might be possible to use the equipment in your own build.
Good luck.
Re: Lighthouse
Post by jim@NAL » Wed Jun 13, 2018 10:09 pm
This is what iv gotta work out some way of making the light .
Re: Lighthouse
Post by Peter Butler » Wed Jun 13, 2018 10:41 pm
On the 'auction site' which shall remain anonymous there are a number of LED strobe lights which you could use and they are not expensive. Instead of the reflector rotating they just light up in sequence as if going round.
invicta280
Re: Lighthouse
Post by invicta280 » Wed Jun 13, 2018 10:43 pm
As Ian says, it is the shield /reflector that controls the light beam. The amount of arc of a circle that the shield covers and the speed of rotation will determine the frequency/duration of the light. I suspect that the shape of the reflector may determine the width or concentration of the light beam. I imagine that for model purposes it doesn't need to be too intense.
edit: If you're ever down this way the older of the two lighthouses at Dungeness is usually open to the public (if you have a head for heights) . An added bonus is the adjacent RH&DR station.
You may have redundant lighthouses open to the public in Suffolk I guess.
IanC
Re: Lighthouse
Post by IanC » Wed Jun 13, 2018 10:50 pm
invicta280 wrote: Wed Jun 13, 2018 10:43 pm As Ian says, it is the shield /reflector that controls the light beam. The amount of arc of a circle that the shield covers and the speed of rotation will determine the frequency/duration of the light. I suspect that the shape of the reflector may determine the width or concentration of the light beam. I imagine that for model purposes it doesn't need to be too intense.
The light is also controlled by a special type of lens, but I agree for model purposes I think that's going too far.
Re: Lighthouse
Post by philipy » Thu Jun 14, 2018 6:32 am
IanC wrote: Wed Jun 13, 2018 9:36 pm
Personally, I wouldn't recommend trying to modify the solar powered garden lighthouses. My wife is a sucker for anything like that and we have had two of them. They are great when new but only last a couple of months before they pack up and stop rotating, then the LED goes subsequently. I did manage to breathe temporary new life into one of them but it went again after a very short length of time.
The other point is of course that they are very small even for 16mm and for 7/8" they would look ridiculous.
Re: Lighthouse
Post by jim@NAL » Fri Jun 29, 2018 11:01 pm
After a night looking on the internet and e bay of orderd some parts to make a start on the lighthouse
Re: Lighthouse
Post by ge_rik » Sat Jun 30, 2018 8:19 am
jim@NAL wrote: Fri Jun 29, 2018 11:01 pm After a night looking on the internet and e bay of orderd some parts to make a start on the lighthouse
Be interested to see how it develops, Jim. Not sure there's much call for it on my railway, supposedly located in the middle of Cheshire, but I do love seeing how others solve logistical challenges.
